garryc Posted November 26, 2020 Share Posted November 26, 2020 I've got a later LT230 with the digital speedo sender which I need to convert to a manual sender to link to my Lightweights (series 3) speedometer. I know I need to think about the number of teeth etc; and i'm really grateful for previous posts on the forum advising on formula to work out which one I will need based on diffs and tyres. But my initial question is can I simply replace the electronic transducer with a geared one which will take a series speedo cable? Or am I looking at this wrong and has anyone a better suggestion? I do want to keep my series speedo. I've looked at digital and GPS but I'd like to retain the look of the series dash. As ever, thank you for your kind assistance. Quote Link to comment Share on other sites More sharing options...
western Posted November 26, 2020 Share Posted November 26, 2020 Just remove the transducer, the speedo drive gear is still in gearbox, just fit the cable into the squared end & secure with a U clip & nut or bolt. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 26, 2020 Share Posted November 26, 2020 As Ralph says. The end of the transducer just replicates the square drive of the end of the speedo cable. What is the end of a series one like? I wonder how the series and early Ninety/OneTen ones match up. If you get stuck, I might still have the speedo cable clip hanging around in my assortment of LR junk valuable parts. Quote Link to comment Share on other sites More sharing options...
missingsid Posted November 26, 2020 Share Posted November 26, 2020 Series speedo cables have a circular plate with three screws to clamp the cable, the later fittings use a single bolt and a "U" clamp that fits the rim of the cable. It may be possible as Western says. In fact it is worth seeing if the round plate on the Series cable will clamp under the "U" clamp as is? Link on this very forum! Speedo cable - LT230 to Series 3 speedo 1 Quote Link to comment Share on other sites More sharing options...
darthdicky Posted November 26, 2020 Share Posted November 26, 2020 Don't bin the electronic one, I had to pay about £75 for a new one when mine was playing up! Worth putting up for sale somewhere. Rich Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 26, 2020 Share Posted November 26, 2020 40 minutes ago, darthdicky said: Don't bin the electronic one, I had to pay about £75 for a new one when mine was playing up! Worth putting up for sale somewhere. Rich Just watch out for which one it is. The Disco one is twice as many pulses compared to the Defender (green) one. Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted November 26, 2020 Share Posted November 26, 2020 12 hours ago, garryc said: I've got a later LT230 with the digital speedo sender which I need to convert to a manual sender to link to my Lightweights (series 3) speedometer. I know I need to think about the number of teeth etc; and i'm really grateful for previous posts on the forum advising on formula to work out which one I will need based on diffs and tyres. But my initial question is can I simply replace the electronic transducer with a geared one which will take a series speedo cable? Or am I looking at this wrong and has anyone a better suggestion? I do want to keep my series speedo. I've looked at digital and GPS but I'd like to retain the look of the series dash. As ever, thank you for your kind assistance. I did this recently. You have to file the end of the series speedo cable down to fit into the defender gear and then secure it to the LT230 using the correct clip and bolt. 1 Quote Link to comment Share on other sites More sharing options...
garryc Posted November 27, 2020 Author Share Posted November 27, 2020 Cracking. Now Ive just got to go and work the ratios out🤔 Thank you so much. Really appreciate it. Quote Link to comment Share on other sites More sharing options...
LiamC Posted November 27, 2020 Share Posted November 27, 2020 I removed the digital speedo drive from a disco 1 box and found that the square drive cable on my 90 was too large to fit the "digital" gear. I had to remove the gear housing and replace the gear (which I planned to do anyway to correctly match the tyre size). So I assume that the digital speedo drive gears are not compatible with the cable drive gears and visa versa. However, as posted above I suppose filing down the cable is another option. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 27, 2020 Share Posted November 27, 2020 Defender drive gears are the same, cable or transducer. Sounds like you may have had an aftermarket parts problem there Liam and you wouldn't be the first. Mo 1 Quote Link to comment Share on other sites More sharing options...
tuko Posted December 1, 2020 Share Posted December 1, 2020 For a correct reading aren't you suppose to replace the Black drive gear with a Blue one? ....... I will be installing a Disco t'case in my Def soon and this was my understanding. Todd. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 1, 2020 Share Posted December 1, 2020 Yes, for 7.50, 235 and 255 tyres. Mo Quote Link to comment Share on other sites More sharing options...
western Posted December 1, 2020 Share Posted December 1, 2020 Blue gear is or was LR Part FRC3310, normally standard fit in 90/110 with the tyre sizes mentioned by Mo. above. https://www.brit-car.co.uk/product.php/86100/0/speedo_drive_20_teeth_blue_discovery_1___defender Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted December 6, 2020 Share Posted December 6, 2020 On 12/1/2020 at 10:58 AM, tuko said: For a correct reading aren't you suppose to replace the Black drive gear with a Blue one? ....... I will be installing a Disco t'case in my Def soon and this was my understanding. Todd. I’ve done that on mine 👍 1 Quote Link to comment Share on other sites More sharing options...
