Will rrc Posted November 30, 2020 Share Posted November 30, 2020 I’ve recently acquired a 94 classic it’s pretty solid, I’m just going to tidy it up a bit and use it for green laning, only problem I’ve got is it’s had a family of rats living in it and they’ve eaten the entire electric window control in the cubby box has anyone else had a similar issue and was wondering if there was a way of retro fitting a panel with carding switches or similar? They all so ate the back seat. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 1, 2020 Share Posted December 1, 2020 Momentary carling switches are swappable for the OE electric window switches, wiring is a bit of a tangle but not too hard once you've worked out how it's supposed to go. Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted December 1, 2020 Share Posted December 1, 2020 Or buy a good used one from a breaker. Quote Link to comment Share on other sites More sharing options...
LiftedDisco Posted February 6, 2021 Share Posted February 6, 2021 Are you sorted yet? Have they eaten the electric window module? If so, i have one and can probably also sort out the relevant bits of loom to replace anything that has been attacked... PM me if you need! Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 7, 2021 Share Posted February 7, 2021 I presume it’s a soft dash. The wiring and switch panel from a 300Tdi Discovery will be the same, and there are plenty of those being broken at any given time. Quote Link to comment Share on other sites More sharing options...
