Stellaghost Posted December 1, 2020 Share Posted December 1, 2020 Picked this up last night from what I can gather it's a 9000i but I haven't a clue what vintage winch engage mechanism is stuck so gonna need a strip down but should be nice once sorted regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 1, 2020 Share Posted December 1, 2020 Yes, 9000i (the “i” stands for integrated, referring to the solenoid pack being encased in the bridge of the housing rather than having a separate casing that can be mounted away from the winch itself (usually in a black plastic box). I’ll be following - it’s the type I have, which I bought second hand from the owners of Protection and Performance and they had just serviced themselves, but I’ve not serviced it since (it has only been used a few times and has never been dunked or gotten muddy, so shouldn’t be too bad). Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 2, 2020 Author Share Posted December 2, 2020 (edited) Hmmm nothing like a basket case to potter on with how grotty is this really it's being an absolute pig to strip down still not got hex shaft and brake assembly to get out yet Looks like bolt heads have been welded they will be a joy to get out !! Anyone got an idea where I can get a bearing end cap for the motor or will I have to improvise regards Stephen Edited December 2, 2020 by Stellaghost Addition 1 1 Quote Link to comment Share on other sites More sharing options...
Daan Posted December 2, 2020 Share Posted December 2, 2020 I would fit a new bowmotor. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 2, 2020 Author Share Posted December 2, 2020 37 minutes ago, Daan said: I would fit a new bowmotor. That's the final option, however, it's not broke until I tell it it's broke lol regards Stephen 2 Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 2, 2020 Share Posted December 2, 2020 Damn! I hope mine isn’t anything like that inside! Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 2, 2020 Author Share Posted December 2, 2020 2 hours ago, Snagger said: Damn! I hope mine isn’t anything like that inside! I think your safe BUT, If it is like this one internally I would be having a very impolite conversation with Protection and Performance about their servicing regime lol regards Stephen Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 3, 2020 Share Posted December 3, 2020 Christ ! 😲 Mo Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 3, 2020 Share Posted December 3, 2020 13 hours ago, Stellaghost said: I think your safe BUT, If it is like this one internally I would be having a very impolite conversation with Protection and Performance about their servicing regime lol regards Stephen I bought it in 2005, and I haven’t serviced it since (because of only using it on a winching course in dry conditions), so I don’t think it’d be reasonable to hold them to account for my laziness! Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 3, 2020 Share Posted December 3, 2020 I have some experience with these Warn winches, we had one on the front of one of our Mountain Rescue vehicles, I stripped it after the clutch seized solid, on opening it was quite horrific how much water was in the gearbox and how little grease there was in there, the grease was also like wax, pretty unimpressed and not surprised that corrosion had happened, I re-filled it with some of the semi grease you use in superwinch husky gearbox's - at least it "wetted" the gears from time time when it ran. Quote Link to comment Share on other sites More sharing options...
Qhriss Posted December 3, 2020 Share Posted December 3, 2020 4 hours ago, Maverik said: I have some experience with these Warn winches, we had one on the front of one of our Mountain Rescue vehicles, I stripped it after the clutch seized solid, on opening it was quite horrific how much water was in the gearbox and how little grease there was in there, the grease was also like wax, pretty unimpressed and not surprised that corrosion had happened, I re-filled it with some of the semi grease you use in superwinch husky gearbox's - at least it "wetted" the gears from time time when it ran. Have used them a lot in Forestry when they are in daily use , on Defenders, still get gunked up and seized ( woodchip is the worse for them ) not a fan, capstan winch better , with a 16mm rope. K Quote Link to comment Share on other sites More sharing options...
bishbosh Posted December 4, 2020 Share Posted December 4, 2020 Paging @Nonimouse 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 5, 2020 Author Share Posted December 5, 2020 Clutch took some getting apart as you can see Starting to look a bit better Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted December 7, 2020 Share Posted December 7, 2020 On 12/4/2020 at 12:13 PM, bishbosh said: Paging @Nonimouse Fairly normal for this type of winch. Water ingress through the freespool lever. 2 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 8, 2020 Author Share Posted December 8, 2020 If there was a society for the prevention of cruelty to winches I'd be reporting this one lol What a carry on getting welded feet bolts out succeeded once I hit on the right method As they were Centre popped Drilled to 6mm Threads then snapped away easily with some stiltsons Regards Stephen Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted December 8, 2020 Author Popular Post Share Posted December 8, 2020 Cleaned up all connections on motor polished commy and renewed bearings Test ran it in vice and working ok both directions happy days regards Stephen 8 Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 9, 2020 Share Posted December 9, 2020 Any news on that end casting? I wonder if Warn can supply them. If not, fabricating one shouldn’t be the end of the world, unless the innards are very complex. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 9, 2020 Author Share Posted December 9, 2020 I do have some news to the tune of £179 + vat, phoned d44 this morning and made some enquiries based on finding a part no warn 61543 which is a motor end cap for warn bic motor 25 dollars in america, d44 are telling me there are non in this country and that part no has been superceded so I politely declined ( they are going to see if they have a second hand one, but I think that will also be astronomically expensive ) gonna see what it costs to get one from America failing that a piece of aluminium billet off eBay for £25 and a couple of hours on the lathe regards Stephen Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 9, 2020 Share Posted December 9, 2020 I have a Chicago trip just before Christmas, and will be visiting the UK for the first week of January. If you like, I can bring it to the UK for you and post it once there, if you have it sent to my hotel. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 9, 2020 Author Share Posted December 9, 2020 Wow very generous offer, have been looking at this, but have since found a picture showing inside cap and it's nothing like what I've got so just gonna make one on the lathe out of billet aluminium once again thank you very much regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Stellaghost Posted December 16, 2020 Author Popular Post Share Posted December 16, 2020 So some progress with motor cover made myself some billet aluminium out of some scrap I had it's not perfect a couple of air bubbles here and there but it will do the job Getting there new and old side by side fitted just got holes to drill and paint regards Stephen 10 Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 17, 2020 Share Posted December 17, 2020 Tidy, should do the job nice effort. Quote Link to comment Share on other sites More sharing options...
Badger110 Posted December 17, 2020 Share Posted December 17, 2020 Proper job Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 17, 2020 Author Share Posted December 17, 2020 Started cleaning solenoid connections up one of the copper joining bars was well corroded so made a new piece and tigged it in looking better now but still to try in earnest regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted December 17, 2020 Author Share Posted December 17, 2020 Getting there and new cover drilled painted and in place regards Stephen Quote Link to comment Share on other sites More sharing options...
