Led indicators
So my front indicator  was playing up so turns out my plug I fitted last year the wire come out of pin that’s fine not bad for a first time of fitting all the lights with plugs but did notice when a bulb is out on standard Land Rover set up it flashes fast but led don’t
something to think about 🤔
no warning 😌
  • Like 1
I thought it was a legal requirement for a fast flash when one indicator fails. Just realised you're right as half of mine aren't plugged in and when I've tested them got a normal flash rate....
Mine are Wipacs so should comply with all regs, I see an E mark on yours too if I'm not mistaken.
😂legal requirements
the police can’t even police a BLM protest so our indicators should be fine 👍
I replaced All the original lights with wipac led lights some years a go but last year I upgraded the loom to td5 compliantly from front to back and inside so the lights needed plugs i did fit green thing right way up the pin connector but this one come out so guess I’m happy only one has come out as was first time doing this conversion,
as for the knob on flasher unit I believe it’s to control the dash light when a trailer is plugged in?
Correct on the adjuster on flasher unit, its moved to stop the trailer ind light on dash flashing when no trailer is attached.
extracted from Road vehicle lighting regs 1989 ----as for failure of one indicator light ---
Quote
However, in the event of a failure, other than a short-circuit of an indicator, any other indicator on the same side of the vehicle or combination of vehicles may continue to flash, but the rate may be less than 60 or more than 120 flashes per minute.
So the rate of flashes is illegal not the light not working?
