Laptom Posted December 11, 2020 Share Posted December 11, 2020 I want to install a 4.6 with serpentine frontcover and new waterpump. No problem so far, but where to connect the return of the heater core? The supply comes from a 3.9 hotwire inlet manifold, but the 4.6 waterpump has no return. Quote Link to comment Share on other sites More sharing options...
Escape Posted December 11, 2020 Share Posted December 11, 2020 You could put a T in the return from the radiator and plumb the return from the heater core to that. Or in the smaller pipe from the reservoir (it's often easier to find a T-pieve with equel diameters). As you probably know, on a 4.6 the thermostat is in an external housing and the return from the heater core goes there (as well as the bypass hose). Filip Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 11, 2020 Share Posted December 11, 2020 I have that set up in my RRC, unequal T in bottom hose of radiator, works perfectly. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 12, 2020 Share Posted December 12, 2020 14 hours ago, Bowie69 said: I have that set up in my RRC, unequal T in bottom hose of radiator, works perfectly. ^ This, I used one of the cheap alloy fan switch adapters off eBay and screwed a hose barb into it instead. 2 Quote Link to comment Share on other sites More sharing options...
Laptom Posted December 19, 2020 Author Share Posted December 19, 2020 Great advice people. I will use the unequal T-piece in the bottom radiator hose. I have a sensor for the electric radiator fans on the top hose, so that is familiar usage. Quote Link to comment Share on other sites More sharing options...
