Peter Horsman 0 Posted January 5 Share Posted January 5 Probably a ninny question, but. The bearing I have taken out of the swivel joint has a cage both sides to stop the rollers from escaping, but the new replacement one only has a cage one side thus allowing the rollers from escaping the other side if the are not parallel. The new bearing was supplied with an inner race, which I guess I don't want and I throw away. Two questions arise; first, have I got the correct replacement bearing (can i get one with cages both sides?) and secondly, which side of the new bearing do I drift into the swivel joint (the cage side or the non-cage side?). Series 3 Lightweight. 1978. I'd be grateful for some guidance please............ Quote Link to post Share on other sites
western 874 Posted January 5 Share Posted January 5 It needs both inner & outer races, otherwise the bearing will be useless https://www.brit-car.co.uk/product.php/368249/0/halfshaft_bearing_front_series_1___111 Quote Link to post Share on other sites
Peter Horsman 0 Posted January 9 Author Share Posted January 9 Thanks, Western. The inner race’s internal diameter is too small to the half shaft, which is the size of the external diameter. The old bearing ran with rollers directly to the half shaft but that was caged both sides of course. I think I’ll clean up the old bearing and grease it up. I bought 244150 but the package said 244150P in places whereas the bearing you have helpfully directed me to says 244150G. Hey ho. Again, thanks for your help. Quote Link to post Share on other sites
western 874 Posted January 9 Share Posted January 9 The P means pattern part, whereas G means genuine but not necessarily a Land Rover boxed part. Quote Link to post Share on other sites
