Arjan Posted March 13, 2021 Share Posted March 13, 2021 Progress !!!! Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 13, 2021 Author Share Posted March 13, 2021 Both hubs and disc's fitted inc new longer wheel studs Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 13, 2021 Author Share Posted March 13, 2021 Both callipers fitted Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 13, 2021 Author Share Posted March 13, 2021 Then i replaced the brake pipes, fitted the halfshafts and bled the brakes but was to late to test, in work tomorrow so i will test them on Monday and go for a drive 🙂 1 Quote Link to comment Share on other sites More sharing options...
Arjan Posted March 13, 2021 Share Posted March 13, 2021 Looking very nice ! have a save testdrive.. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 14, 2021 Author Share Posted March 14, 2021 12 hours ago, Arjan said: Looking very nice ! have a save testdrive.. Cheer's mate Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 14, 2021 Share Posted March 14, 2021 Good to see it coming along now. Nice that they put the discs on the right side of the hub flanges - LR were bloody stupid doing it the way they did, needing a hub strip to replace a disc. Do the callipers need new brake lines? Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 14, 2021 Author Share Posted March 14, 2021 9 minutes ago, Snagger said: Good to see it coming along now. Nice that they put the discs on the right side of the hub flanges - LR were bloody stupid doing it the way they did, needing a hub strip to replace a disc. Do the callipers need new brake lines? They came with new brake pipes but as the kit is a direct copy of the front kit the pipes was too short so had to make new ones up 🙂 Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 14, 2021 Share Posted March 14, 2021 That’s a pain. At least you can keep them as spares for the front. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 14, 2021 Author Share Posted March 14, 2021 46 minutes ago, Snagger said: That’s a pain. At least you can keep them as spares for the front. Yeah, my bro came round on Saturday who used to be into landy's and classic Jag's and thinks the kits are classic Jag parts and Zeus does stuff for classic Jag as well. 1 Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted March 14, 2021 Share Posted March 14, 2021 So to fit that kit is it remove the drum backplate, fit the calliper bracket, fit the disc with extended studs and then fit the calliper? Have you had to remake the rigid pipe from the T piece on the rear axle for both callipers? Everything else standard Series? Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 14, 2021 Author Share Posted March 14, 2021 2 minutes ago, Bigj66 said: So to fit that kit is it remove the drum backplate, fit the calliper bracket, fit the disc with extended studs and then fit the calliper? Have you had to remake the rigid pipe from the T piece on the rear axle for both callipers? Everything else standard Series? Yes its as simple as that, the hard part is swapping the studs over but thats not hard really tbh 😃 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 15, 2021 Author Share Posted March 15, 2021 Well i've been out all day in the landy covered over 100 miles and the brakes are great but what i have noticed is under normal braking if feels like the just front brakes are working but if i pump the pedal just once it then feels like all the brakes are working so i'm not sure if there is still some air in the system or if i do need a bigger master cylinder so i will give it another bleed at the weekend and see. 1 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 15, 2021 Author Share Posted March 15, 2021 (edited) On 1/6/2021 at 12:52 PM, Arjan said: Easy fitting : Arjan, what setup are you using for master cylinder, are you using a servo and or do you have a compansator valve fitted, just trying to find out what i'm missing if re-bleeding the brakes doesn't work 😉 All i'm using is a series universal master cylinder that can be used for either a brake or clutch master cylinder, no servo or compensator valve fitted. Edited March 15, 2021 by Cornish Rattler Quote Link to comment Share on other sites More sharing options...
Arjan Posted March 15, 2021 Share Posted March 15, 2021 Goedeavond, TTBOMK I have the standard Series LWB MBC with servo off a 109"export as we initially had the bigger drum up front set up. No bias valve. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 15, 2021 Author Share Posted March 15, 2021 1 hour ago, Arjan said: Goedeavond, TTBOMK I have the standard Series LWB MBC with servo off a 109"export as we initially had the bigger drum up front set up. No bias valve. Thanks Arjan, i will try and sorce them, think i will need the bigger 5 way connector as well 👍 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 16, 2021 Author Share Posted March 16, 2021 1 hour ago, Cornish Rattler said: Thanks Arjan, i will try and sorce them, think i will need the bigger 5 way connector as well 👍 Unless i go with the single line servo and S3 single line master cylinder 🙂 Quote Link to comment Share on other sites More sharing options...
Diff Posted March 16, 2021 Share Posted March 16, 2021 13 hours ago, Cornish Rattler said: Unless i go with the single line servo and S3 single line master cylinder 🙂 I very strongly suggest swapping to a dual circuit master cylinder. My heavily laden 1959 109 suffered total brake failure at speed downhill on a track in Tanzania. A brake pipe fractured on the back axle causing loss of braking on all 4 wheels due to the single circuit. A scary descent for the 4 of us into a dry river bed using very gentle use of the hand brake to slow us a bit. Using the hand (transmission)brake at speed can snap the half shafts and cause total loss of control particularly if you have Rover axles as opposed to a Salisbury. We were lucky the river bed was wide, dry and sandy and that we didn't hit anything. Regards, Diff. 2 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 16, 2021 Author Share Posted March 16, 2021 35 minutes ago, Diff said: I very strongly suggest swapping to a dual circuit master cylinder. My heavily laden 1959 109 suffered total brake failure at speed downhill on a track in Tanzania. A brake pipe fractured on the back axle causing loss of braking on all 4 wheels due to the single circuit. A scary descent for the 4 of us into a dry river bed using very gentle use of the hand brake to slow us a bit. Using the hand (transmission)brake at speed can snap the half shafts and cause total loss of control particularly if you have Rover axles as opposed to a Salisbury. We were lucky the river bed was wide, dry and sandy and that we didn't hit anything. Regards, Diff. Ok Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 16, 2021 Share Posted March 16, 2021 50 minutes ago, Diff said: I very strongly suggest swapping to a dual circuit master cylinder. My heavily laden 1959 109 suffered total brake failure at speed downhill on a track in Tanzania. A brake pipe fractured on the back axle causing loss of braking on all 4 wheels due to the single circuit. A scary descent for the 4 of us into a dry river bed using very gentle use of the hand brake to slow us a bit. Using the hand (transmission)brake at speed can snap the half shafts and cause total loss of control particularly if you have Rover axles as opposed to a Salisbury. We were lucky the river bed was wide, dry and sandy and that we didn't hit anything. Regards, Diff. Agreed, seems a bit daft to upgrade your braking system by fitting discs, and then to not have possibly the simplest braking safety upgrade in there as well! Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 16, 2021 Author Share Posted March 16, 2021 Thanks guys for all this info but i just want to see if there is any air in the system first, just waiting for a brake bleeder to arrive as me and son bled the brakes but i don't always have him to hand so once it comes i will give them another bleed, i will also check that the rod on the master cylinder doesn't need adjusting and if that doesn't sort it then i will look into replacing the master cylinder to a better one and a servo and servo pedal box 🙂 Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted March 17, 2021 Share Posted March 17, 2021 Some interesting information on various master cylinder applications here. https://www.onallcylinders.com/2013/10/15/tech-brake-master-cylinder-faqs/ Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 17, 2021 Author Share Posted March 17, 2021 1 hour ago, Bigj66 said: Some interesting information on various master cylinder applications here. https://www.onallcylinders.com/2013/10/15/tech-brake-master-cylinder-faqs/ Thats answard a lot of questions, so deffo need a bigger master cylinder then. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 17, 2021 Author Share Posted March 17, 2021 2 hours ago, Cornish Rattler said: Thats answard a lot of questions, so deffo need a bigger master cylinder then. I've also emailed Zeus to see what they suggest as well Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 18, 2021 Author Share Posted March 18, 2021 Not heard out from Zeus yet but i've just adjusted the rod on the master cylinder and its better and feels like all 4 wheels are working together now 🙂 Quote Link to comment Share on other sites More sharing options...
