missingsid Posted March 18, 2021 Share Posted March 18, 2021 1 hour ago, Cornish Rattler said: Not heard out from Zeus yet but i've just adjusted the rod on the master cylinder and its better and feels like all 4 wheels are working together now 🙂 This is one area that I focused on, since the travel of both the M/C and the pedal is limited then the the amount of play in the linkage is important. As I am using a M/C from a servo system I got the info from the workshop manual. This enabled me to ensure that I got the max pedal travel possible which exceeded the M/C travel. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 18, 2021 Author Share Posted March 18, 2021 3 hours ago, missingsid said: This is one area that I focused on, since the travel of both the M/C and the pedal is limited then the the amount of play in the linkage is important. As I am using a M/C from a servo system I got the info from the workshop manual. This enabled me to ensure that I got the max pedal travel possible which exceeded the M/C travel. Yeah when i first fitted the front disc kit it never accured to me that the mast cylinder would need adjusting but the after fitting the rear kit and had to pump the pedal i put it down to pos air in the system more than rod adjustment but thought i would give it a go and see and has made a difference. Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 20, 2021 Author Share Posted March 20, 2021 Tip run today with trailer on so will see how they are with the trailer on and weight 🙂 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted March 20, 2021 Author Share Posted March 20, 2021 4 hours ago, Cornish Rattler said: Tip run today with trailer on so will see how they are with the trailer on and weight 🙂 Yeah everthing ok 👍 Quote Link to comment Share on other sites More sharing options...
