Arjan 350 Posted January 7 Share Posted January 7 This year, this Ifor Williams trailer found its way into the circus here and so far we're quite happy with it. Ifor Yes, reflections boards were fitted by me as I like them a lot to make the trailers as visible as possible.. Question 1 : The foglight does not seem to be connected to PIN 2 (54G) - is there a special IW wiring thing ? Question 2 : Does anybody know what LED units will a +/- direct swop for these bulb units ? Thanks ! . Quote Link to post Share on other sites
western 882 Posted January 7 Share Posted January 7 Any square LED light should fit, the top right on this site for example https://www.towingandtrailers.com/products/trailer-parts/trailer-lights/rear-trailer-lights/led-rear-lights/3-function-led-lights/ rear fog light is IIRC on a blue wire at pin 2 https://www.westerntowing.co.uk/trailer-caravan-12n-wiring-diagram/ 7 pin trailer wiring is common, shouldn't think Ifor trailers would be any different. Quote Link to post Share on other sites
L19MUD 272 Posted January 7 Share Posted January 7 and if you want to make that fog light LED it looks identical to a Defender one? Quote Link to post Share on other sites
toenden 6 Posted January 8 Share Posted January 8 Hi Arjan, Good idea with the reflection boards, but should they not have been the other way around so trafik from behind gets pointed to the sides around the trailer in a similar way that roadsigns point to the pasning side? (I know, i know, penny pickling, but my ocd flipped 🙂) /mads Quote Link to post Share on other sites
Arjan 350 Posted January 8 Author Share Posted January 8 Idea behind the boards as they are fitted now is that they point sort of outwards - making a flow around the trailer regardless of on what side of the road I drive.... They are seriously visible.. We have put a feed on all 7 pins and the fog light will not come up. It does work when a direct feed is done on the light so I assume a cable problem. So a rewire seems to be on the list of jobs... Many thanks for the link ! Quote Link to post Share on other sites
elbekko 382 Posted January 8 Share Posted January 8 1 hour ago, Arjan said: We have put a feed on all 7 pins and the fog light will not come up. It does work when a direct feed is done on the light so I assume a cable problem. So a rewire seems to be on the list of jobs... It's trailer wiring... of course a rewire is necessary. Quote Link to post Share on other sites
Blanco 158 Posted January 8 Share Posted January 8 Ifor trailers usually have 'proper' junction boxes under the floor, worth checking for them, and just make sure all is well on the inside. Quote Link to post Share on other sites
Arjan 350 Posted January 8 Author Share Posted January 8 Ok - interesting... I'll have a look under the thing.. Quote Link to post Share on other sites
