pinny Posted January 13, 2007 Share Posted January 13, 2007 i have a 300tdi n plate discovery what is the correct amp battery i fitted new s motor cleaned all connections on a cold morning still turns over slowly it has a 100 amp alternator charging ok maybe a dodgy batt Quote Link to comment Share on other sites More sharing options...
western Posted January 13, 2007 Share Posted January 13, 2007 Standard battery is a 072 which is 72amp/hour for the 300Tdi with 100amp alternator. for ref LR part number is STC8267 for all 300Tdi engined Discovery. Quote Link to comment Share on other sites More sharing options...
pinny Posted January 14, 2007 Author Share Posted January 14, 2007 Standard battery is a 072 which is 72amp/hour for the 300Tdi with 100amp alternator. for ref LR part number is STC8267 for all 300Tdi engined Discovery. cheers for that that aint what is on there ill change it thanks Quote Link to comment Share on other sites More sharing options...
steve_a Posted January 16, 2007 Share Posted January 16, 2007 if you get stuck you can fit a 334 - i did tonight, something liek 690 CCA and 155 a/h . They didn't have any 072 in halfords, span some dit about how the can't get any and the factory is making them. I needed a battery then and there so just went for the next one that would fit with the terminals the right way around Quote Link to comment Share on other sites More sharing options...
Andy Posted January 16, 2007 Share Posted January 16, 2007 most places ive looked at Tdi disco batts they list a 067 or 072 for HD use. i always get 072s but you may have smaller fitted without it being 'wrong' as it were. Quote Link to comment Share on other sites More sharing options...
pinny Posted January 17, 2007 Author Share Posted January 17, 2007 thanks guys it supposed to get colder the weekend so ill get one the weekend Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted January 18, 2007 Share Posted January 18, 2007 Don't forget to disable the alarm before you remove the battery Done it too many times and always takes about 5 mins to turn the damn thing off again, by which point the neighbours are poking their heads out the windows giving me evils. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 18, 2007 Share Posted January 18, 2007 It's nice that you think your neighbours stare at you because of the alarm Go to a battery place (and not a Kwik-fit one, a proper commercial place) and just get them to give you the biggest battery that will fit in the hole. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted January 18, 2007 Share Posted January 18, 2007 It's nice that you think your neighbours stare at you because of the alarm You ought to see the looks they give me when I start up the blue thing Normally whilst wearing ski goggles and a very silly hat.... Quote Link to comment Share on other sites More sharing options...
