geoffbeaumont Posted January 16, 2021 Share Posted January 16, 2021 2 hours ago, BogMonster said: Depending on the configuration of the site and the building if you can put the doors in the ends then headroom for roller doors is less of a problem. My doors are 3m x 2.8m to fit the boat in and I was over-cautious on headroom inside because of the sloped approach and the boat A frame but there ended up being plenty of room. Don't forget it doesn't cost much to make a building a bit higher because mostly it's fresh air, the materials cost of making the walls a foot higher is very little. That's looking from the perspective of having built a timber framed garage but it should translate (more or less) into a constructed building as well as it is no more effort to build or erect a 3.5m high wall than it is to erect a 3m high wall. Provided it doesn't require planning permission - permitted development in the UK (i.e. right to build without formal planning consent) is subject to height limits especially near boundaries. Quote Link to comment Share on other sites More sharing options...
Badger110 Posted January 16, 2021 Share Posted January 16, 2021 I believe he was talking about cost, it’s a lot cheaper to go up a few feet than add foundations to extend it Quote Link to comment Share on other sites More sharing options...
missingsid Posted January 16, 2021 Share Posted January 16, 2021 I am so depressed now, I used to have a powered garage, now I only have a damp container! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 16, 2021 Share Posted January 16, 2021 47 minutes ago, missingsid said: I am so depressed now, I used to have a powered garage, now I only have a damp container! A cheap 12v solar panel & a PC fan might help circulate some air, keep it less sweaty? Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted January 18, 2021 Share Posted January 18, 2021 On 1/16/2021 at 3:02 PM, Badger110 said: I believe he was talking about cost, it’s a lot cheaper to go up a few feet than add foundations to extend it I was meaning once you get into needing planning consent what might have been a very cheap, hassle free job can rapidly escalate. Getting planning consent isn't a major cost considered as part of a major extension - it hurts if you're only doing a very small job. 3 Quote Link to comment Share on other sites More sharing options...
missingsid Posted January 19, 2021 Share Posted January 19, 2021 On 1/16/2021 at 7:45 PM, FridgeFreezer said: A cheap 12v solar panel & a PC fan might help circulate some air, keep it less sweaty? I used to have a large Ring solar panel but it was not as waterproof as I thought! The instructions do warn about that but being a bloke I did not read it all! Did look at van rotary vents but they are £70 for a simple plastic fan and swivel! As I am not looking to keep the battery charged as per the Ring one I will look at see what is around. Thanks. Quote Link to comment Share on other sites More sharing options...
