Green200tdi Posted January 10, 2021 Share Posted January 10, 2021 (edited) I’m looking at replacing the rear cross member as the rest seems ok I’m thinking of this no rails, any advice ? 1986 110 csw Edited January 10, 2021 by Green200tdi Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted January 10, 2021 Share Posted January 10, 2021 You can work around the different rear tub mounting rail instead of tabs, but the old type fuel tank and cradle will not fit, it changed in 1998 to the plastic tank arrangement. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted January 10, 2021 Share Posted January 10, 2021 I would get one with legs. They'll rot through in a few years if not already. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted January 11, 2021 Share Posted January 11, 2021 2 hours ago, dailysleaze said: I would get one with legs. They'll rot through in a few years if not already. If it can be done without legs it is a better job and less rot prone. 1 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 11, 2021 Author Share Posted January 11, 2021 21 hours ago, oneandtwo said: You can work around the different rear tub mounting rail instead of tabs, but the old type fuel tank and cradle will not fit, it changed in 1998 to the plastic tank arrangement. This one has what I need even the 7 pin plug hole, well that’s I use it for, not sure what you mean about working round tabs and that but it’s for an old 110 🤔 Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted January 11, 2021 Share Posted January 11, 2021 1 hour ago, Green200tdi said: This one has what I need even the 7 pin plug hole, well that’s I use it for, not sure what you mean about working round tabs and that but it’s for an old 110 🤔 By all means buy it then, but you won’t be able to fit your fuel tank without modifications. and you are going to have to weld tabs on the rear face of the cross meter too as that one has the adjustable rail designed to sit on the inside face of the later rear tub rail, not the outside. and your tow hitch won’t fit without modifications because they changed the mounting arrangements in 1998 Quote Link to comment Share on other sites More sharing options...
