brandtjcasey 0 Posted January 11 Share Posted January 11 I purchased what was titled as a 1988 Defender. The drivers side rear axle shaft sheared and I can not find a replacement. I found a local guy with a lot of knowledge who has informed me its not a defender but some kind of santana. The shaft is 10 splines on both sides and measures 29.5 inches end to end. Can anyone tell me where I can find this shaft. Quote Link to post Share on other sites
Blanco 158 Posted January 12 Share Posted January 12 Welcome... Santana stayed with leaf springs so telling a Defender 90 from a swb Santana should be straightforward (always assuming it hasn't been subject to major alteration!?). Are there not any body /chassis plates to tell you what the vehicle is? In the absence of plates, post some more pics of the vehicle and we might have more of a clue where to start. The numbers and pics you have already put up don't mean much to me but then I don't have much Series/90 axle knowledge or any Santana so that isn't perhaps surprising. 10 spline shafts are known to be the weakest in general, if the failure occured doing something you regularly do then maybe consider some upgrades anyway? Quote Link to post Share on other sites
mickeyw 169 Posted January 12 Share Posted January 12 Hi and welcome. That shaft end looks distinctly of the leaf sprung LR style. The threaded end and split pin hole are the telltale signs. I've not seen a more recent Santana shaft. Coil sprung axle shafts are splined to the end and have a circlip groove around the outside diameter. I'll echo that some more photos of the vehicle will help us identify what you have. Quote Link to post Share on other sites
RedLineMike 131 Posted January 12 Share Posted January 12 https://www.ebay.co.uk/itm/Land-Rover-Half-Shaft/174529165796?epid=2028031397&hash=item28a2bfb9e4:g:PWIAAOSw-wZfunDc not sure if that helps? Quote Link to post Share on other sites
Daan 410 Posted January 12 Share Posted January 12 Hi, and welcome to the fold. It looks like a standard 10 spline series shaft, but beware: the santana did change the track width at some stage, to have wider axles. So double check the length of the shaft before you buy. Daan Quote Link to post Share on other sites
brandtjcasey 0 Posted January 12 Author Share Posted January 12 It is leaf sprung and I’ve been told it looks like a lr shaft but the length is odd Quote Link to post Share on other sites
brandtjcasey 0 Posted January 12 Author Share Posted January 12 Here is a pic put together Quote Link to post Share on other sites
Daan 410 Posted January 13 Share Posted January 13 Nice truck; You definitely have the wider axles, so it needs to be a santana specific shaft. Quote Link to post Share on other sites
andy _1 9 Posted January 16 Share Posted January 16 Hi do you have any photos of underneath, ie the transferbox , props and if possible the engine. It looks like a 90 but the roof is that pressed folds in it. Is it leaf or coil spring. Show us the chassis or engine , has someone put different axels on it? Take pictures underneath thats screaming 90 to me. I sure those santana things you can see the leaf spring from the front. Like this. This has interested me i am editing this again, I going to go out on a limb thats a 90. The axles don't know! but that body's a 90 from the air vents ect those santana don't have vents like the 90 or bonnet hindges like the 90. There is noway a santana has a 90s bulkhead. I just read that it's leaf sprung ,is this a series with 90 wings , front panel with santana axels? Quote Link to post Share on other sites
Maverik 566 Posted January 17 Share Posted January 17 Really interesting truck, looks a bit like this one: https://images.app.goo.gl/bF4btAsYywajy9QFA Land Rover Santana 2500DL or a DC2500. but yours seems to have been Defenderised a little more. Quote Link to post Share on other sites
andy _1 9 Posted January 17 Share Posted January 17 2 hours ago, Maverik said: Really interesting truck, looks a bit like this one: https://images.app.goo.gl/bF4btAsYywajy9QFA Land Rover Santana 2500DL or a DC2500. but yours seems to have been Defenderised a little more. Yup your right thats what it is, thats like a clone of a 90 , how did they get away with making them and landrover said nothing? Thinking are the bulkheads interchangeable?😀 well he knows what he needs now a shaft from a 1990 2.5 santana. Quote Link to post Share on other sites
western 882 Posted January 17 Share Posted January 17 Santana were Spanish LR licenced builders for that market, all LR approved & originally made up the CKD kits of vehicles sent from UK, Spain law required more local content so they stayed with the leaf springs & more locally sourced parts, the ladt model was the Santana PS10 Amibal, Thecontract with LR ceased in mid 1980's IIRC, they also built Suzuki samaria SJ's as well. Santana was bought out by Iveco which built a revised Anibal but called Iveco Massif, but it ceased production after a few years, & no longer exist as new vehicles. https://en.m.wikipedia.org/wiki/Santana_Motor Quote Link to post Share on other sites
