andy _1 Posted January 15, 2021 Share Posted January 15, 2021 I got a 2.5 td 90 converted to 200 tdi the heater plugs have never worked, with this lock down nonsense I thought I would look. I assume I missing a feed one terminals bare see pic. Where does the feed meant to come from battery or starter? Any help much appreciated. Thanks Andy Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted January 15, 2021 Share Posted January 15, 2021 The 200Tdi doesn't need heater plugs down to 0°C. Therefore I use a manual switch and a relais to activate them for some 10 seconds when temps are really low. They draw about 60 Amps. Makes the harness and the schematic a lot easier. In summertimes I use the same switch for switching on the el. fan on the radiator. It will seize easily, when not used ... and that happens quite quickly on a 200Tdi Quote Link to comment Share on other sites More sharing options...
andy _1 Posted January 15, 2021 Author Share Posted January 15, 2021 Thanks that given me something to consider wire then to a switch. Thanks Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted January 15, 2021 Share Posted January 15, 2021 If that's the correct terminal it's just a length of wire from that terminal to the number 4 heater plug and they will be wire as per the TD. That's how I did my 200 conversion from 19J. Quote Link to comment Share on other sites More sharing options...
Arjan Posted January 15, 2021 Share Posted January 15, 2021 I have a 6 mm2 wire and a manually operated relais to feed the glowplugs on the Tdi's. Simple and works very well Quote Link to comment Share on other sites More sharing options...
andy _1 Posted January 15, 2021 Author Share Posted January 15, 2021 Yes that bare terminal goes live when the key goes to heat position. Problem is the brown wire with red tracer goes into the bulk head into a rubber type box from the heater plugs. I have no idea where it goes to , can't find it without dismantling my dash. Does the brown wire with the red tracer go to the heater plug nearest the bulk head? Mine goes all the way to the front nearest the radiator. I always thought that was weird. I am thinking someone ones pulled the wire all the way through, can anyone confirm this? Quote Link to comment Share on other sites More sharing options...
monkie Posted January 15, 2021 Share Posted January 15, 2021 Yes, on the pre Tdi engines the thick brown with red trace goes from the ignition switch to the glowplug nearest the bulkhead (cylinder 4). Edit: usually the glowplugs are fed by the brown/red to number 4 and then yellow/black carries the power to the rest in series. Quote Link to comment Share on other sites More sharing options...
western Posted January 15, 2021 Share Posted January 15, 2021 As above, the ignition switch terminal should be marked with a 1, on converted vehicles [like my 110] the thick brown/red is disconnected & insulated as the 200Tdi wiring is different, I removed the brown/red competely some time ago, it now powers my headlight relays direct from alternator output. Quote Link to comment Share on other sites More sharing options...
Chubby M Posted April 28, 2021 Share Posted April 28, 2021 Gents - sorry to jump in on this but I'm having a very similar issue. I have a 19J Brown / Red from cycl4 and the yellow / blck carrier etc... When I stripped the truck (5 years ago - I know, not rushing this rebuild) the glow plugs worked like a dream, and oddly I have a small carrier wire from cyl 4 to the dash warning light. On reassembly I now have a running truck, but, no feed on the Brown /Red at cycl. 4. Warning lights etc. are on at ignition position 1 etc.. I can see no inline fuses / relays etc. that may have failed so I'm bemused. Any ideas please? Does the glow plug wire somehow pass through the master fuse board? (I've checked all the fuses and they look ok) IS there any other fail point? I've yet to strip the ignition and check that. Really appreciate any ideas as I'm now lost..... Quote Link to comment Share on other sites More sharing options...
