mad_pete Posted January 16, 2021 Share Posted January 16, 2021 As I'm not a mega wincher these days looking to move from my big rear tub hydraulic tank to a small one in the battery tray. Not sure if I should mod the tray or just find a small tank to fit. Quote Link to comment Share on other sites More sharing options...
steve b Posted January 16, 2021 Share Posted January 16, 2021 It might be easier to remove the whole battery tray/box then mount from top of tank to seatbox underside with spacer brackets to suit ? Steve Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 16, 2021 Share Posted January 16, 2021 My H14W came with an under-seat hydro tank, they cut a square hole under the driver's seat box and the tank had a flange along either side that bolted up with rivnuts in the remainder of the seatbox - it was quite narrow and you have a fitting sticking out the bottom. Not really sure how much it held, guess maybe 5-10L by the time you've got the clearance for the vent/filler on top. Quote Link to comment Share on other sites More sharing options...
Escape Posted January 17, 2021 Share Posted January 17, 2021 I fitted a tank of around 20l under the RH seat my TD5, after relocating the ECU. I did consider cutting out the seat box and mounting with brackets, but as I could just get it to fit in the box I never bothered. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 17, 2021 Share Posted January 17, 2021 Yrm do a flat bottom Ali battery tray if that helps. Mike Quote Link to comment Share on other sites More sharing options...
simonr Posted January 17, 2021 Share Posted January 17, 2021 For a winch, if you have an oil (hydraulic fluid) cooler, you only need a tiny tank! It's really only to replace fluid that's lost in use and a bubble-trap to get rid of air in the system. The purpose of bigger tanks is to act as a buffer in the cooling (where the heat generated exceeds the cooling capacity) giving you longer run times before the oil gets too hot - and to compensate for the difference in swept volumes at either end of hydraulic cylinders. Motors and pumps are mostly fairly constant volume. Even with a larger than standard battery, there's still space in the battery box for a tank without having to extend the bottom. Si Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 17, 2021 Share Posted January 17, 2021 Running a few bits of steel pipe rather than all rubber hose helps cooling too, some LR factory "coolers" for PAS/fuel/oil are just a loop of steel pipe. 1 Quote Link to comment Share on other sites More sharing options...
