Les Brock Posted January 14, 2007 Share Posted January 14, 2007 SVA ....speedo ? I'm a bit concerened that my speedo might be under reading slighly, which it will fail on... Are all the head units the same as in calibration ?, and anyone know what drive for an 1.4/230 transfer on 3.54 diffs with 265/75/16's will need for it to read correctly Ta ! Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted January 14, 2007 Share Posted January 14, 2007 265's are equiavalent to a 750x16, so go with the 110 speedo drive gear. Kev Quote Link to comment Share on other sites More sharing options...
western Posted January 14, 2007 Share Posted January 14, 2007 SVA ....speedo ?I'm a bit concerened that my speedo might be under reading slighly, which it will fail on... Are all the head units the same as in calibration ?, and anyone know what drive for an 1.4/230 transfer on 3.54 diffs with 265/75/16's will need for it to read correctly Ta ! all 90/110 speedo's are common across the range except for the Td5 electronic version, but all use the gear drive, you need the blue frc3310 as used in all 110 with 7.50 or 235/85 tyres, I run 255/85 tyres & my speedo is within 4mph of my gps. hth Quote Link to comment Share on other sites More sharing options...
Les Brock Posted January 14, 2007 Author Share Posted January 14, 2007 Thank you both Ordered ! Quote Link to comment Share on other sites More sharing options...
western Posted January 14, 2007 Share Posted January 14, 2007 No probs LEs, best wishes for the SVA test, hope you get a good result Quote Link to comment Share on other sites More sharing options...
LR90 Posted January 14, 2007 Share Posted January 14, 2007 Yeh, best of luck with the test Les Quote Link to comment Share on other sites More sharing options...
callum Posted January 14, 2007 Share Posted January 14, 2007 if its any help, my 110 was almost spot on with that combo, 265's were pretty worn and when i say spot on i mean exactly the same as my dad's passat which was used in convoy for testing. i have 285's now so its probably out a bit now Quote Link to comment Share on other sites More sharing options...
