TD5Spain Posted January 14, 2007 Share Posted January 14, 2007 Hi Again Does anyone have the dimensions of an original TD5 intercooler as fitted to a 1999 90 without aircon please? Lying "redundant in the LHside front wing behind the headlamp I have a maroon/ brown plastic electrical connector. This has a constant positive feed and 2 switched positves from the ignition and one negative, I think! Does anyone know what it is for? Thanks Quote Link to comment Share on other sites More sharing options...
D9OSV Posted January 14, 2007 Share Posted January 14, 2007 It will either the plug for the factory fit alarm unit (Have you got one?) or posibly for headlight levelling. This is normal don't panic, Landrover fit one wiring harness and add extras to the vehicle depending on spec etc... Jim Quote Link to comment Share on other sites More sharing options...
TD5Spain Posted January 14, 2007 Author Share Posted January 14, 2007 It will either the plug for the factory fit alarm unit (Have you got one?) or posibly for headlight levelling.This is normal don't panic, Landrover fit one wiring harness and add extras to the vehicle depending on spec etc... Jim Thanks again I have a factory alrm fitted and headlight levelling which does not work so I will investigate... Cheers Quote Link to comment Share on other sites More sharing options...
