SlickV8 Posted January 25, 2021 Share Posted January 25, 2021 Hi All, i'm building my S2 back up [going sooo slow as STILL waiting for autospark to install new loom - 3 months and counting Grrrr] Anyway, I 've been playing with the cooling and although it starts & seems to run OK I cant help but feel the cooling isnt plumbed quite right: as the fan & new heater arnt yet wired i cant do too much but... Its a RR Classic 3.5 V8 / edelbrock manifold, 4 barrel weber with a wing mounted expansion tank. This has a small [main?] outlet top left and a small one in the neck under the filler cap [overflow?] and i've converted to waterless coolant. The radiator is quite large and has two small inlets [outlets?] top right and the standard larger top and bottom hoses, the only filler for the radiator is a screw in square top bolt top right. Currently I have it plumbed as; 1. Top & Bottom larger hoses - self explanatory. 2. expansion tank filler neck to radiator top right small 3. expansion tank main outlet small to radiator top/lower right small 4. waterpump - [viewed from the front] short 'S' hose, righthand inlet into front inlet of manifold and larger hose, W/Pump left outlet into heater then heater-out into the back of the inlet manifold Am i right in thinking i should have a vacuum connection from the expansion tank [top left outlet] from the front bottom of the carburettor? - in the pic i mean the right hand one that currently has a short blanked off hose on it, marked by a red circle; dont laugh but i'm nervous about connecting a waterpipe to a carburettor vacuum If so, I'm left with a spare inlet [outlet?] on the the top right of the radiator...so plug that or 'T' into one of the other pipes? Thanks in advance Nick Quote Link to comment Share on other sites More sharing options...
