uninformed Posted January 27, 2021 Share Posted January 27, 2021 Not sure if the K stands for Kustom, Kettle or Kursed lol 1998 300Tdi Defender 110 Cab Chassis. Bought in 2000 with 28k on it, stock other than a ARB bull bar. It was my daily driver, work truck , only vehicle for 17 years until I parked it up because of yet another head gasket failure... The 300Tdi got changed out for a HS 2.8 Tgv at ~270k due to eating the crank (big ends bearings went, apparently bad batch from factory in a 3 month period of 98') It had done a HG about 12 months earlier, requiring a new head. The HS 2.8 has had its fair share of problems, some my fault, some who bloody knows! On park up it had, F&R MaxiDrive lockers, MD Hyd PTO, MileMaker winch, MD 40% lower low range. Home made sliders and tube bar. Mach 5 rims. 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 27, 2021 Author Share Posted January 27, 2021 Vent cut in left guard for better cooling. Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 27, 2021 Author Share Posted January 27, 2021 SO it sat for a couple of years while I took care of other things. When the dust had cleared I figured I could get into the modifications I had always wanted to do.... Starting with longer Radius arms. Chassis work first. 3mm fish plate, tying in with crossmember bolts. New RA mount and bracing. 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 27, 2021 Author Share Posted January 27, 2021 Then the rear fish plate, and new trailing arm mounts including strengthening, plus some little tie ins/bracings. 2 Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 27, 2021 Author Share Posted January 27, 2021 Then some longer traiing arms, A frame arms and modified/strengthend body outriggers. Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 27, 2021 Author Share Posted January 27, 2021 New A frame cross member with end plates incorporating link mounts. Cross member and body outriggers welded in. Some where along the line I sold the MD locked Sals, and built a custom rear Rover housing....madness right! 🤣 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 27, 2021 Author Share Posted January 27, 2021 End caps/transitions and some bits for the radius arms 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 27, 2021 Author Share Posted January 27, 2021 Custom laminated and widened front housing. This is the original 98' housing so has the 7 bolt swivels, TRB top and bottom, but ill be using early stub axles and hubs for the wider bearing spacing. 75mm wider each side. Bolts will be replaced with ARP studs. 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 27, 2021 Author Share Posted January 27, 2021 I had to remove the spring mounts to have good access to the weld at flanges. Back on they went. 3 Quote Link to comment Share on other sites More sharing options...
Arjan Posted January 27, 2021 Share Posted January 27, 2021 You've been busy !! Impressive welding. 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 27, 2021 Author Share Posted January 27, 2021 11 minutes ago, Arjan said: You've been busy !! Impressive welding. Thanks. Slow going and lots left to do. Just have to keep chipping away at it. Next will be finishing radius arms and start on shorten rear overhang and new rear cross member. Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted January 27, 2021 Share Posted January 27, 2021 Clearly not your first go with the hot metal glue gun. What are you doing about extending the half shafts? Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 27, 2021 Author Share Posted January 27, 2021 Just now, daveturnbull said: Clearly not your first go with the hot metal glue gun. What are you doing about extending the half shafts? Funny story about that, I had a guy start, great welder but unreliable and terrible communication so I taught myself on this build. Getting new shafts made by MaxiDrive out of Hytuf. They know all the dimensions for the locking spline etc and make excellent shafts. They will be 24/23 spline. Running Genuine GKN RRC cvs with custom stub shafts out of Hytuf and anti burst rings out of 4140. They are the same length as the AEU2522 early 110 cv Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 27, 2021 Share Posted January 27, 2021 What's the square access panel on the axle casing? Locker actuator? Quote Link to comment Share on other sites More sharing options...
Blanco Posted January 27, 2021 Share Posted January 27, 2021 Interesting thread!. You've obviously got the knack of the welder. Often see people anxious to lift their trucks here (and crank the arms), but seldom see anyone go the longer arm route. Are those new mounts available down under or is all that stuff fabbed for the job? 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 27, 2021 Author Share Posted January 27, 2021 7 hours ago, bishbosh said: What's the square access panel on the axle casing? Locker actuator? Yes it’s the weld on block for actuator. Billet aluminium cylinder bolts to it, and has a vacuum operated piston that has a selector fork attached. That slides a locking collar along splines on the axle shaft and will engage/disengage dogs on the end of the carrier/hemisphere. Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 27, 2021 Author Share Posted January 27, 2021 1 hour ago, Blanco said: Interesting thread!. You've obviously got the knack of the welder. Often see people anxious to lift their trucks here (and crank the arms), but seldom see anyone go the longer arm route. Are those new mounts available down under or is all that stuff fabbed for the job? The trailing arm and radius arm mounts are LR chassis replacement parts. But all the fish plates, overlapping tie ins , braces and everything else are hand cut and fabricated. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted January 27, 2021 Share Posted January 27, 2021 Very nice work! Keep the updates coming! Steve 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 27, 2021 Share Posted January 27, 2021 49 minutes ago, steve200TDi said: Very nice work! Keep the updates coming! Steve Agreed ! Welding looks incredible Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 28, 2021 Author Share Posted January 28, 2021 15 hours ago, steve200TDi said: Very nice work! Keep the updates coming! Steve 14 hours ago, Anderzander said: Agreed ! Welding looks incredible Thanks. Its been quite an interesting and challenging learning curve. Welds on Suspension links needed to be X Ray tested and we did some destructive tests as well. These sorts of modifications need to be approved by a certifying engineer registered with Dept Of Transport. Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted January 28, 2021 Share Posted January 28, 2021 Wow that is cracking, excellent work! 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 28, 2021 Share Posted January 28, 2021 3 hours ago, uninformed said: Thanks. Its been quite an interesting and challenging learning curve. Welds on Suspension links needed to be X Ray tested and we did some destructive tests as well. These sorts of modifications need to be approved by a certifying engineer registered with Dept Of Transport. And people here complain about our rules on mods Very tidy work. 2 Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted January 28, 2021 Share Posted January 28, 2021 Regarding the front radius arms, something I've seen before on a comp safari car that I thought was pretty cool, was to use Disco 2 type chassis mounts, and an extension piece that screwed onto the standard defender arms, lengthening them by about 12" or so. This gives the obvious advantage of longer arms whilst being able to keep the stock (strong) cast ones, and the better design of the Disco 2 chassis bushings. I think it was on a Tomcat type thing, might well have been a custom job tho. Quote Link to comment Share on other sites More sharing options...
dangerous doug Posted January 28, 2021 Share Posted January 28, 2021 Nice work, I think @landroversforever may want a look at the spacers 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted January 28, 2021 Author Share Posted January 28, 2021 5 minutes ago, daveturnbull said: Regarding the front radius arms, something I've seen before on a comp safari car that I thought was pretty cool, was to use Disco 2 type chassis mounts, and an extension piece that screwed onto the standard defender arms, lengthening them by about 12" or so. This gives the obvious advantage of longer arms whilst being able to keep the stock (strong) cast ones, and the better design of the Disco 2 chassis bushings. I think it was on a Tomcat type thing, might well have been a custom job tho. Yes the D2 axle bushes are quite good. I’m using Nissan Patrol bushes at axle end. The pin style isn’t so bad as it allows for the rotation during articulation. It will be a bit more limited in travel compared to a D2 style chassis bush, but being longer the angle of bush deflation is reduced. I’m only running 12” shocks so shouldn’t be a problem. BTw, I’m pretty sure the LR radius arms are forged not cast, and yes they are strong and ductile which is good. I’ve heard some evidence that they mostly fail (bend/buckle) sideways. I’m hoping to do some bend tests on a factory arm and a test one of mine to compare. Quote Link to comment Share on other sites More sharing options...
