MikeD Posted February 1, 2021 Share Posted February 1, 2021 I have been searching but am unable to find anyone that sells this particular type of channel insert for sliding side windows. It basically looks to be the webbing material that you used to get on rucksack straps (if you are old enough) it measures around 1.8mm thick and about 21mm wide. It obviously gets its shape from the aluminium channel (10mm wide by 10mm high) it is just pushed in and goes round the rounded corners nicely I might be able to use the smallest woolies channel type but if I can get this original type I would prefer to do so I did try some of the land rover felt but that is too thick to get the 4.9mm window glass in Quote Link to comment Share on other sites More sharing options...
miketomcat Posted February 2, 2021 Share Posted February 2, 2021 I've not used it on the side windows but I used the Woolies small window channel on my doors. They had the same original channel as you've pictured. The Woolies channel has worked well and having used it at work should go round the side window radius with no problems. Mike Quote Link to comment Share on other sites More sharing options...
MikeD Posted February 8, 2021 Author Share Posted February 8, 2021 not sure of the etiquette in replying to your own thread but..... I found some really good channel for this job and thought I would share https://www.ebay.co.uk/itm/FLOCKED-LINED-RUBBER-SLIDING-WINDOW-CHANNEL-UPTO-4-6MM-GLASS/224144606416 it takes a little practice to fit and I found a small pair of blunt nosed pliers (jewellers size) was best another job off the list only 5,783 to go 😀 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted February 8, 2021 Share Posted February 8, 2021 Useful supplier , saved to my ebay - thanks Mike Not many jobs left to do , finished next week then ... Steve Quote Link to comment Share on other sites More sharing options...
