Fufflenarnia Posted February 6, 2021 Share Posted February 6, 2021 Hi all, I have my ms2x system running really well on my 3.9 v8. But. I cant get it to switch over to lpg, omvl doesn't like the feed for some reason, I've tried: Tachofix feed Tacho feed from ms through a +ve fed coil Wire wrapped around a plug lead Feed from a coil pack. I've tried all options with the 4 feed settings available in omvl millenium Occasionally, when cranking with the battery almost flat, the system will jump into life. Help! Quote Link to comment Share on other sites More sharing options...
=jon= Posted February 11, 2021 Share Posted February 11, 2021 Do you have the diagnostics lead - does the gas ECU show an RPM feed in the diag software? I'm running a GasItaly ECU straight from the RPM feed from the MS.. Quote Link to comment Share on other sites More sharing options...
Fufflenarnia Posted February 11, 2021 Author Share Posted February 11, 2021 Thanks, Yes, it shows it briefly, on diag, around 30 rpm and then stops after 5 to 10s And all goes to 0. I'm going to go over the wiring this weekend. Quote Link to comment Share on other sites More sharing options...
elbekko Posted February 11, 2021 Share Posted February 11, 2021 Make sure your grounds are good, and preferably tied together for both ECUs. Quote Link to comment Share on other sites More sharing options...
