DiveTramp Posted February 21, 2021 Share Posted February 21, 2021 The above vehicle has very heavy steering, notchy at times then light then notchy and heavy again. I have replaced the two U/J's as they were actually loose in the joints. I see oil coming from the swivels, so ive got those to look at. My real question is... what number should the steering pump be? The thing fitted to my One Ten (it has a 200tdi dropped in) has the number BR1361 on the pump label. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 21, 2021 Share Posted February 21, 2021 There are two types of 200Tdi pump, the earlier type is common with the previous 2.5TD (19J) engine while the later one is unique to the 200Tdi. Engine number will help determine which yours should have, or some decent pics of the hose connections as they differ between the pipes. The fitment to the engine bracket is the same. Quote Link to comment Share on other sites More sharing options...
Will@LRW Posted February 21, 2021 Share Posted February 21, 2021 One of two part numbers as per this thread: Diagram is here: https://www.lrworkshop.com/diagrams/land-rover-defender-engine/200tdi/power-steering-pump_53159#1 I would first check that the belt is tight enough and isn't slipping. My 300Tdi's belt slips on damp mornings and produces notchy steering until the belt has dried a bit Quote Link to comment Share on other sites More sharing options...
DiveTramp Posted February 21, 2021 Author Share Posted February 21, 2021 Cheers. Engine number is 11L 24763A. The pump does indeed appear to have a little leak going on. That leak is from the front, there is a banjoed pipe on the rear and the feed pipe is a push on to the top of the round body. It also has S200 Pump on the label and the belt is tight enough. If I'm going to replace the leaky pump, I'll need to know which one to get... 😉 Quote Link to comment Share on other sites More sharing options...
western Posted February 21, 2021 Share Posted February 21, 2021 If you read through that post which is linked above you will find the correct part number & photo. 1 Quote Link to comment Share on other sites More sharing options...
