Landy90 Posted February 22, 2021 Share Posted February 22, 2021 Hi all, hoping this is the right place. Ive recently took ownership of a land rover 90 with a range of classic 4.3 v8 engine in it with a efi flapper. Im able to get the engine to start and idle but if I try to rev it, it cuts out. Ive got enough fuel. Any thing else i should check please Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 22, 2021 Share Posted February 22, 2021 First place would be the ignition amplifier, likely on the side of the distributor if it is a 4.2 (they did maybe a 4.3, but only in Aus.... as the P76) or possibly a slightly sick fuel pump/blocked fuel filter, though this is only based on the "it will idle, but not rev" information. For proper fault finding, there is a whole load of fault diagnosis stuff in the tech archive: Follow that through and you will likely find something amiss. Other thing to check is for basic mechanical condition, split hoses, crusty coils etc all give an ECU a hard time trying to run the engine. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 22, 2021 Share Posted February 22, 2021 ^ what Bowie said. Also - has it been stood for a long time, has it been fiddled with, was it running when parked / running recently, has anything changed since it last ran right? Quote Link to comment Share on other sites More sharing options...
