giacomo.m Posted March 12, 2021 Share Posted March 12, 2021 Hi all, as I am replacing the rear air springs, the new spring has this type of connection different from the original now I would kindly like to know if I have to cut the tube and remove the brass union "o" ring type in order to fit the new spring also I would kindly like to know if any changes need to be made to the ACE leverage after an 2 " lift kit thank you Giacomo Quote Link to comment Share on other sites More sharing options...
bear Posted March 14, 2021 Share Posted March 14, 2021 Hi, All new bags seem to have the push in "voss" connectors so you will have to cut the brass olive off and push the pipe into the new connector. Make sure you cut it clean and square. If you have to remove it in future you just push the collar in and pull the pipe out. I think you have to remove the white protective plastic piece in your photo - just check. Can't help on ACE as I don't have it. Regards, Griff Quote Link to comment Share on other sites More sharing options...
giacomo.m Posted March 14, 2021 Author Share Posted March 14, 2021 Hi thank you bear ,that's exactly what I did, also the piece of white protective plastic does not need to be removed but is part of the " voss " connector Giacomo Quote Link to comment Share on other sites More sharing options...
giacomo.m Posted March 20, 2021 Author Share Posted March 20, 2021 Hi, on the other hand, regarding the linkage of ACE, nobody can help me ? thank you Giacomo Quote Link to comment Share on other sites More sharing options...
