defender dinky Posted March 26, 2021 Author Share Posted March 26, 2021 Hone?, you mean clean, rub down, with buffer in the drill, blocks on bench upside down atm can't pull pistons through, mates got me engine stand tied up at his,dd Quote Link to comment Share on other sites More sharing options...
Peaklander Posted March 26, 2021 Share Posted March 26, 2021 (edited) Honing puts the swirls back on the polished bores and these then retain lubrication. I had mine honed in-situ and the job was done in about 45 mins by a mobile service. It cost £60-80 can't remember exactly. I had lots of advice from people on here as I had no idea what was needed! Edit: this is my 300TDi so the bores face upwards. I guess yours is a little more challenging. 😀 Edited March 26, 2021 by Peaklander Quote Link to comment Share on other sites More sharing options...
defender dinky Posted March 28, 2021 Author Share Posted March 28, 2021 Don't know if i should put this here or start a new post, Cleaning engine today and come across the engine number, I presume this means its a suffix B engine, where I read somewhere they were only used for about 10 months before changing to suffix C, whats the other number for, dd Quote Link to comment Share on other sites More sharing options...
Escape Posted March 28, 2021 Share Posted March 28, 2021 25D would make it a 3.5 EFI auto 9.35, 1986 onward. Does that sound correct? Filip Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted March 29, 2021 Share Posted March 29, 2021 On 3/25/2021 at 8:54 PM, defender dinky said: Maybe my screen resolution is carp, but those journals don't look happy to me. Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted March 29, 2021 Share Posted March 29, 2021 12 hours ago, defender dinky said: Don't know if i should put this here or start a new post, Cleaning engine today and come across the engine number, I presume this means its a suffix B engine, where I read somewhere they were only used for about 10 months before changing to suffix C, whats the other number for, dd CR is the compression ratio of the motor. 9.35 in this case, by the look of it. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted March 29, 2021 Author Share Posted March 29, 2021 8 hours ago, JohnnoK said: Maybe my screen resolution is carp, but those journals don't look happy to me. Cleaned them up Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted March 30, 2021 Share Posted March 30, 2021 15 hours ago, defender dinky said: Cleaned them up Mmmmm, much betterer, now! Quote Link to comment Share on other sites More sharing options...
defender dinky Posted March 30, 2021 Author Share Posted March 30, 2021 Waiting for crankshaft and con rod bearing, cam shaft came minus the end bolt, but luckily for me, the seat belt anchor bolts from a discovery 1, are the same thread which I had a few spare, dd Quote Link to comment Share on other sites More sharing options...
defender dinky Posted March 30, 2021 Author Share Posted March 30, 2021 Just gone to truck and this keeps seeping, how do I disconnect it without damaging it Quote Link to comment Share on other sites More sharing options...
