This mornings project
Stellaghost
37 minutes ago, CwazyWabbit said:
It's a support for when turning things through the lathe headstock to stop them whipping about.
No sorry
1 hour ago, landroversforever said:
Adjustable height support for something long you're working on? Like one of the screw top pipe stands?
Near enough
It's for supporting long sections of steel in my bandsaw regards Stephen
  • Like 1
That was a great guess! Should have thought of that having seen the aftermath of someone not using one with about 2m of 12mm stainless bar out the back of the headstock :ph34r:
But it was still wrong 😂
  • Haha 1
  • 2 weeks later...
I did a little trial today with the welder, still learning!
I've got some 3mm steel on the floor of the garage that I picked up from a local garage, which was a miscommunication as I thought it was 3mm aluminium, you can guess my surprise when I went to collect it as it was 10ft x 4ft :blink:
Anywho, it's been on the floor for nearly a year and I cut bits off it for various jobs but today decided I'd have a go at making a fire pit with it.
Template made from top of the range cardboard
FDF99E17-0820-44FE-BE91-05D6398EA4BD.thumb.jpeg.3050042b062cd6a71eb7ec3d2b9b0582.jpeg7ECA09A8-BEF7-4DAD-B523-D44B58144F93.thumb.jpeg.33133ec256897cae61186ab7b3fa7d42.jpeg
I then cut it out and scored the fold lines and bent it in the vice
Welded it up
added some side bits, chucked some legs on and voila!
It's not straight, the welds are abit holey in places where the folds didn't join and the legs are tacked on as I will probably change the bits around the edge, but it certainly won't blow away as it weighs quite abit!
  • Like 3
As I never liked what I’d done I had a go at improving it.
tidied up the side and cut a hole in the bottom with a slide out tray to empty the ash from
61D13929-A921-4E1B-AA1E-BB586CFCA0C5.thumb.jpeg.6cfccd8a3126cbb6e21eb515fc71f136.jpeg292F7198-2056-43FE-833B-0E8D0EDC2A94.thumb.jpeg.8262cdb3b3ff0e064403cda19b79c0b6.jpegC93A55B3-72F1-4A97-ABC8-B6DEB457448D.thumb.jpeg.4ee336d3e24fe47daa4c100600d19513.jpeg
I’ll be making some legs out of scrap box section and maybe a shelf to hold some logs
  • Like 1
2 hours ago, paime said:
That's come out really well! How did you create the folds? Angle grinder then a bit of heft to bring the corners together?
Yup, exactly that!
Cardboard is great as it has movement if the cuts aren’t great with a template, but the funny thing is, steel doesn’t do that! Que lots of grinding and filling with weld to make a smooth edge
it just so happens it’s the sister in laws birthday today so it has become a ‘ oh bugger I forgot ‘ petrol station kind of present...I’m sure she’s always wanted one 😁
  • Haha 3
16 hours ago, Badger110 said:
Yup, exactly that!
What you’re really gifting with petrol station presents is a lifetime of being the butt of her jokes about it, so she should be very pleased indeed!
On 4/4/2021 at 10:19 AM, monkie said:
Indeed. What I'm doing is inspired by @ianmayco68 custom dash.
I have tacho, coolant and fuel in the main binnacle, then I have some aluminium sheet I'm making a new dash slightly angled towards the driver to house the boost, EGT, oil pressure, oil temp, volt meter and a USB socket. I'll put up a picture when I've sorted it out
I am also an admirer of Ian's custom dash, and I wish that I had the skills to do something like that.  So far, I've limited my dash mods to a Mudpod addition when I fitted an EGT gauge.  I'm surprised that you're putting the fuel gauge in the main binnacle.  Unless you're in the "Oh carp, we're nearly out of fuel!" situation you only need to look at the fuel gauge every hour or so, since fuel level moves relatively slowly - except in a V8, whereas the EGT can change in seconds, and be very damaging if not recognised immediately.  For these reasons I've mounted my fuel gauge in a Mudpod on top of the dash and fitted the EGT gauge where the fuel gauge normally is.
Mike
Mike
You make a very good point.
Firstly, I have to admit that I read Ian's custom dash thread and realised the if I had a go it would not look anywhere near as good so I opted for the Mud console. I might have a go at a whole dash one day as a project at my leisure.
Secondly, you are absolutely right. After 2 or 3 short trips I came to the same conclusion as you have described. I switched the guages round so in the main binnacle I have coolant temperature, EGT and a clock.
  • 2 weeks later...
On 4/4/2021 at 9:45 PM, crclifford said:
Not a this morning project, but having 10 days self isolation following a trip overseas means I get to crack in plastering the house....5 days = 82  20kg bags of lime hemp plaster on the walls and nearly 2 rooms base coated. Only another 98 bags to go to finish the delivery off....lots more still to do.
employee monitoring
so what have you decided to do in this place?
something special or a small renovation in general?
it reminds me of a great place for harry potter haha
