P38 Paul Posted April 5, 2021 Share Posted April 5, 2021 Hi peeps , I may have a problem with my N/S/F wheel bearing/hub & would like to know when ordering if the same part fits both sides or are they handed ? Also is there anything I should look out for when doing the job or is it pretty straight forward , regards Paul . Quote Link to comment Share on other sites More sharing options...
Northwards Posted April 5, 2021 Share Posted April 5, 2021 (edited) I think the hubs are handed at the front, but not at the back. If you're equipped with a big press then I believe the bearings can be pressed out - but this is only stuff I've read as I don't have any kind of press. Depending on when the area was last maintained, then getting the hub out of the steering knuckle could be a bit of a pain. Make sure you have removed the ABS sensor (and even that can be a pain - mine broke and I had to get replacements). Then, if you have an old brake disc to hand, you could reverse fit that back onto the hub and hit the back of it to try and separate the two. Or put a couple of the hub to knuckle bolts in from the back and whack them. I soaked it all in plusgas/wd40 a couple of days in advance and then started work. Having tried the things above, and presumably had some impact, I then took a hefty punch to the hub and tried tapping it round, and eventually started gently tapping a chold chisel into the line between knuckle and hub. Once there's a bit of a gap it's easy enough. PS - meant to say I took my hubs out with the halfshafts attached as I didn't want to disturb the bearings/stake nut. I was pretty confident my bearings were OK, so that was one less job to do. If you're def replacing the hub and/or bearing then having the half shaft / CV joint out of the way would probably help. Edited April 5, 2021 by Northwards 1 Quote Link to comment Share on other sites More sharing options...
elbekko Posted April 5, 2021 Share Posted April 5, 2021 1 hour ago, Northwards said: If you're equipped with a big press then I believe the bearings can be pressed out - but this is only stuff I've read as I don't have any kind of press. Yes, but we've bent our cheapo 20T press a few times doing that. They don't come easy. 1 hour ago, Northwards said: Or put a couple of the hub to knuckle bolts in from the back and whack them. This works pretty well, yes. I hope you have a big impact for the CV nut, that one can be a person I'm not that keen on. Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted April 13, 2021 Author Share Posted April 13, 2021 Just a quick update , I got the wheel bearing changed & everything went ok but I am still suffering a bad vibration at around 30 mph through the steering wheel , this vibration started just before I changed the wheel bearing which I thought was a progression of the bearing breaking down but it wasn't , has anyone got any ideas because I am giving up with this very unreliable vehicle . Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted April 13, 2021 Share Posted April 13, 2021 2 hours ago, P38 Paul said: Just a quick update , I got the wheel bearing changed & everything went ok but I am still suffering a bad vibration at around 30 mph through the steering wheel , this vibration started just before I changed the wheel bearing which I thought was a progression of the bearing breaking down but it wasn't , has anyone got any ideas because I am giving up with this very unreliable vehicle . Propshaft? Quote Link to comment Share on other sites More sharing options...
Northwards Posted April 13, 2021 Share Posted April 13, 2021 Sticky brake caliper? I had a nasty front wobble. It began coming on ca. 50mph, but on other occasions it was apparent right down to twenty or so. Kind of by chance, I noticed that one wheel was burning hot - hot enough to melt the tyre valve cap.... On investigation I found that particular caliper slider wasn't working, brakes staying on, on one side, and causing a wobble at certain speeds. I did take the opportunity to do all of the front ball joints and bushes, more or less a complete rebuild. No wobble now, and the front is really tight. Just got the back to do now! I know it can be a pain to be permanently struggling with small things, but once you start dealing with them, on a methodical basis, then its a case of better the devil you know, than the one you don't? Quote Link to comment Share on other sites More sharing options...
Blanco Posted April 14, 2021 Share Posted April 14, 2021 +1 for a close look at the front driveshaft, ... and if poss raise and support the axle clear of the ground to free things up, I had a mysterious vibration for ages , it wasn't until I checked the prop uj's myself, (instead of taking the tyre shops word for it) that I found the problem. Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted April 14, 2021 Share Posted April 14, 2021 Paul I had the front prop on my first P38 fail the day after I had it MOT'd it took out the floor pan and the gearbox so definately worth checking the UJ's even it it isn't them. Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted April 14, 2021 Author Share Posted April 14, 2021 1 hour ago, Simon_CSK said: Paul I had the front prop on my first P38 fail the day after I had it MOT'd it took out the floor pan and the gearbox so definately worth checking the UJ's even it it isn't them. Hi Simon , Took the front prop out today & the UJs feel a little worn but I dont think it would have been enough to make all that noise , however we will see as I have ordered new ones & will post back on here with the outcome once fitted , watch this space 😔 Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted April 14, 2021 Author Share Posted April 14, 2021 21 hours ago, Northwards said: Sticky brake caliper? I had a nasty front wobble. It began coming on ca. 50mph, but on other occasions it was apparent right down to twenty or so. Kind of by chance, I noticed that one wheel was burning hot - hot enough to melt the tyre valve cap.... On investigation I found that particular caliper slider wasn't working, brakes staying on, on one side, and causing a wobble at certain speeds. I did take the opportunity to do all of the front ball joints and bushes, more or less a complete rebuild. No wobble now, and the front is really tight. Just got the back to do now! I know it can be a pain to be permanently struggling with small things, but once you start dealing with them, on a methodical basis, then its a case of better the devil you know, than the one you don't? Hi , took both of the front brakes apart to inspect them & found everything ok , I have ordered new front prop shaft UJs to see if that sorts things out 🙄 Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted April 18, 2021 Author Share Posted April 18, 2021 Simon , take an apple out of the bag as your reward , you was spot on with your diagnosis about the front prop shaft , nice one all is good , up & running now as it should be . 2 Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted April 18, 2021 Share Posted April 18, 2021 5 hours ago, P38 Paul said: Simon , take an apple out of the bag as your reward , you was spot on with your diagnosis about the front prop shaft , nice one all is good , up & running now as it should be . Thanks Paul. Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted April 19, 2021 Author Share Posted April 19, 2021 You are welcome Simon & thanks for the great suggestion , bye the bye , did you ever find any of those lower windscreen trim clips that I was after some time ago ? Quote Link to comment Share on other sites More sharing options...
