Cornish Rattler 202 Posted Tuesday at 03:42 PM Share Posted Tuesday at 03:42 PM Hi guys I have just replaced my Defender 200tdi FIP ( fuel injection pump ) with a 300tdi injection pump, the engine is a Def 200tdi engine that I have dressed as a Disco 200tdi and now fitted with a 300tdi injection pump, the pump seems to pull slightly better from lights and junctions but seems to pull slower through the gears but keeps pulling, with the Def pump I couldn't go into top gear less than 32 mph as the engine laboured were as the 300 pump I can go into top about 25 mph which is better but I will give the pump a better test on the motorway tomorrow but I suppose it's getting used to a std 300 pump as appose to being used to a tweaked Def 200tdi pump so will see tomorrow 1 Quote Link to post Share on other sites
Cornish Rattler 202 Posted Wednesday at 11:18 AM Author Share Posted Wednesday at 11:18 AM (edited) Gave the landy a good run out had it on the Mway and i got it upto 80 mph on the flat and would probably go more but i am happy with that,where as before with the Def pump it would only do 70 mph 👍 Edited Wednesday at 12:22 PM by Cornish Rattler Quote Link to post Share on other sites
Nonimouse 243 Posted Thursday at 08:29 AM Share Posted Thursday at 08:29 AM Did you run into any issues with the swap? Are you running the 200 turbo? Quote Link to post Share on other sites
Cornish Rattler 202 Posted Thursday at 11:52 AM Author Share Posted Thursday at 11:52 AM (edited) 3 hours ago, Nonimouse said: Did you run into any issues with the swap? Are you running the 200 turbo? No problem just wasn't sure how to use the timing took kit i bought as it was slighly different to the ones i'd seen but worked in out in the end, using a 300tdi turbo 🙂 Obviously with it being a tdi in a series i had to remove the rad as not much room to work but if it was a Def or Disco you would probably have the room. Edited Thursday at 11:55 AM by Cornish Rattler 2 Quote Link to post Share on other sites
