Godber Posted April 19, 2021 Share Posted April 19, 2021 I am about to change my existing RR diffs for a matched pair (same vehicle) and counted 46 teeth on the crown, and 16 on the pinion. Now I'm somewhat surprised, I expected to find the usual 13 teeth on what I thought was a 3.54:1 diff (removed from a Range Rover classic V8) Anybody? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 19, 2021 Share Posted April 19, 2021 Any stamped markings on the outside edge of the crownwheel? or end of the pinion? Quote Link to comment Share on other sites More sharing options...
steve b Posted April 19, 2021 Share Posted April 19, 2021 I think another check of the tooth count is needed . I'm not aware this was a ratio ever supplied to any Rover/Land Rover axle? Welcome to the forum too Steve b 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 19, 2021 Share Posted April 19, 2021 Comes out at 2.875:1.... I know KAM did a 2.8, and I think ashcrofts might now? It's possible also a Jag or Rover ratio from memory too. But as before, check for some numbers and the tooth count. 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted April 19, 2021 Share Posted April 19, 2021 Ashcrofts currently show 3.50:1 as the highest non-std. ratio available on their site with tooth count of 28/8 KAM R&P set's on Craddocks show 3.8:1 and lower although the details for this set do talk of 2.83 ratio R&P sets too but nothing listed on the site Steve Quote Link to comment Share on other sites More sharing options...
Godber Posted April 19, 2021 Author Share Posted April 19, 2021 7 hours ago, steve b said: I think another check of the tooth count is needed . I'm not aware this was a ratio ever supplied to any Rover/Land Rover axle? Welcome to the forum too Steve b Thank You Steve, believe me, I have counted again and again, even used tippex to mark the first tooth I counted, it is correct Quote Link to comment Share on other sites More sharing options...
Godber Posted April 19, 2021 Author Share Posted April 19, 2021 8 hours ago, landroversforever said: Any stamped markings on the outside edge of the crownwheel? or end of the pinion? Yeah well, I should have checked that, but now they are fitted it's too late for that. Maybe I'll pull the rear diff out again and have a look, it's easy on the Series 3 axle. Quote Link to comment Share on other sites More sharing options...
steve b Posted April 19, 2021 Share Posted April 19, 2021 It would appear you have a vehicle set of KAM high ratio R&P gears then - sorry about asking the bleeding obvious but had to check I couldn't find any tooth count for this ratio on the 'net but KAM would seem to still be about , no website but contact phone no's listed if you want to find out more Steve Quote Link to comment Share on other sites More sharing options...
Godber Posted April 20, 2021 Author Share Posted April 20, 2021 8 hours ago, steve b said: It would appear you have a vehicle set of KAM high ratio R&P gears then - sorry about asking the bleeding obvious but had to check I couldn't find any tooth count for this ratio on the 'net but KAM would seem to still be about , no website but contact phone no's listed if you want to find out more Steve How interesting, I removed them myself from a rolling chassis of a Range Rover classic, expecting the obvious and never bothered to check straight away, only during the fitting, curiosity got the better of me and I started counting. Thank You very much for all the help! Quote Link to comment Share on other sites More sharing options...
western Posted April 20, 2021 Share Posted April 20, 2021 Ask Nige Hybrid from hell on here, he knows a fair bit about KAM parts. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 20, 2021 Share Posted April 20, 2021 @Hybrid_From_Hell What's the tooth count on a KAM 2.8 CW&P set? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 21, 2021 Share Posted April 21, 2021 KAM 283 is 51 and 18, so its defo not a KAM gearset ! 1 Quote Link to comment Share on other sites More sharing options...
Godber Posted April 21, 2021 Author Share Posted April 21, 2021 Right, I'm going to pull the rear one out again and have a look for any sort of markings, time to shed some light I say! Thanks for all the help and suggestions 1 Quote Link to comment Share on other sites More sharing options...
Godber Posted April 21, 2021 Author Share Posted April 21, 2021 1 hour ago, Hybrid_From_Hell said: KAM 283 is 51 and 18, so its defo not a KAM gearset ! The only thing I found online, was this 16 teeth pinion, early Range Rover RTC4489 Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 22, 2021 Share Posted April 22, 2021 RTC4489 is 10 splne internal gears for a early 2 pin center ? Quote Link to comment Share on other sites More sharing options...
L19MUD Posted April 22, 2021 Share Posted April 22, 2021 https://www.shop4autoparts.net/parts/axle-suspension/rtc4489-diff-g-kit-16-9t-10-spl-suf-a/ Quote Link to comment Share on other sites More sharing options...
Godber Posted April 23, 2021 Author Share Posted April 23, 2021 On 4/22/2021 at 9:06 AM, Hybrid_From_Hell said: RTC4489 is 10 splne internal gears for a early 2 pin center ? I am pulling the rear diff out tomorrow to check if there are any markings, and I will take some photos. Quote Link to comment Share on other sites More sharing options...
Godber Posted April 24, 2021 Author Share Posted April 24, 2021 What can I say, Steve was right, another count was needed, only this time the correct pinion wheel. Yes, my first time on this forum, and I already manage to make an Ass of myself, and successfully wasted everyone's time. My apologies, next time I will investigate more thoroughly, before I ring the alarm bells. (Now I'm going to hide and let grass grow over this) Quote Link to comment Share on other sites More sharing options...
steve b Posted April 24, 2021 Share Posted April 24, 2021 We all have the occasional brain fart , just good to get to the bottom of it . Pun for free Good to have you around godber , enjoy the forum Steve 1 Quote Link to comment Share on other sites More sharing options...
