moose Posted January 16, 2007 Share Posted January 16, 2007 Only on my first cup of coffee so my brain is still a bit dull... and iam sure some one will be able to answer this very quickly if looking at the v8 block from the front (water pump end) is pot 1 the first on the left bank or the right? . This is just to clear up a discussion I am having thanks for the input...... Quote Link to comment Share on other sites More sharing options...
jameslwt Posted January 16, 2007 Share Posted January 16, 2007 Have you still not got that MG back on the road?! Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted January 16, 2007 Share Posted January 16, 2007 On your right. Normally, right and left are considered from the point of view of sitting in the car, so that's actually the left cylinder bank: Front 1 - 2 3 - 4 5 - 6 7 - 8 Back Quote Link to comment Share on other sites More sharing options...
moose Posted January 16, 2007 Author Share Posted January 16, 2007 On your right.Normally, right and left are considered from the point of view of sitting in the car, so that's actually the left cylinder bank: Front 1 - 2 3 - 4 5 - 6 7 - 8 Back thanks for that the confusion was from looking at the V8 engine manual as it has Firing order 1, 8, 4, 3, 6,5, 7, 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Cylinders 1, 3, 5, 7 - LH side of engine Cylinders 2, 4, 6, 8 - RH side of engine cos if i have done the manual i would have put the RH lin above the LH line and this engine rebuild has been on of those projects where you do lots, and then nuthing for a month or two so i now cant remember which pot i had at TDC when i did the timming chain and jameslwt you know that answer to that! too busy fixing landrovers and helping you Quote Link to comment Share on other sites More sharing options...
jameslwt Posted January 16, 2007 Share Posted January 16, 2007 that and spending monday evenings pulling van delivery drivers out of 'slightly muddy greenlanes' when they've sunk up to their axles! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 16, 2007 Share Posted January 16, 2007 What I want to know is where are cylinders 5, 6, 7 and 8 on these "TDi" things 'cos they sound really rough, as if they're not even there Quote Link to comment Share on other sites More sharing options...
Lewis Posted January 16, 2007 Share Posted January 16, 2007 What I want to know is where are cylinders 5, 6, 7 and 8 on these "TDi" things 'cos they sound really rough, as if they're not even there They make up the left hand bank on the engines I work on mmmm Lion V8 Quote Link to comment Share on other sites More sharing options...
