steve b Posted May 14, 2021 Share Posted May 14, 2021 Jim, Try www.keithgott.co.uk , they should have the technical expertise for this , most UK LR parts specialists now are just parts distributors . www.rst-landrovers.co.uk might also be able to help , although they are more Defender orientated these days . If my stock engine had the correct one I would have sent it to you , but as I said it's two random springs hooked together . good luck and let us know how you get on . I've not asked , but is the other end anchored to a small tab on the oil filter housing top bolt ? Steve Quote Link to comment Share on other sites More sharing options...
83county88 Posted May 15, 2021 Author Share Posted May 15, 2021 Steve, Thanks for the referrals. I will give it a try. And yes, the low end of the spring does attach to the tab on the oil filter housing top bolt. I will let you know how I get on with this issue. I am currently at my vacation home in north Idaho; I will be home on 22 May and will again get back to working on my Series. Jim Quote Link to comment Share on other sites More sharing options...
