davidlandy Posted January 16, 2007 Share Posted January 16, 2007 If the tappets were massively out of adjustment on a 200 tdi, say .040 +, rather than .010 what would be the symptoms? would it cause: misfiring excess crankpressure forcing oil into the air cleaner more noticeable engine braking thanks Dave Quote Link to comment Share on other sites More sharing options...
JST Posted January 16, 2007 Share Posted January 16, 2007 mine jsut made lots of ticking noise! Quote Link to comment Share on other sites More sharing options...
nige90 Posted January 16, 2007 Share Posted January 16, 2007 Lots of tappy noises and a drop in power. Quote Link to comment Share on other sites More sharing options...
western Posted January 16, 2007 Share Posted January 16, 2007 would have thought it'd be down on power & very noisy on the top end of the engine. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted January 16, 2007 Share Posted January 16, 2007 Down on power... the engine would be acting very "asthmatic" as the valves wouldn't be open for long enough, or far enough. a bit like you going for a run, and only opening your mouth half way and taking short breaths. enging braking might be marginally better as the gasses in the cumbustion chamber won't be able to get out as quickly, so you'd be keeping the compression in the cylinder for a fraction longer. or is that statement utter cr@p? Quote Link to comment Share on other sites More sharing options...
nige90 Posted January 16, 2007 Share Posted January 16, 2007 or is that statement utter cr@p? Sounds logical enough. Quote Link to comment Share on other sites More sharing options...
davidlandy Posted January 16, 2007 Author Share Posted January 16, 2007 so if the valves are shut longer, is it possible that it could cause more crank case pressure to force oil out? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 17, 2007 Share Posted January 17, 2007 Don't think so. The cylinder is designed to hold the pressure anyway, It just holds it at a different time than it should. If you have excessive crank case pressure, then it's probably something EXPENSIVE! Les. Quote Link to comment Share on other sites More sharing options...
Tonk Posted January 17, 2007 Share Posted January 17, 2007 excess crank case pressure can be blown head gasket, worn bores or broken rings. Quote Link to comment Share on other sites More sharing options...
davidlandy Posted January 17, 2007 Author Share Posted January 17, 2007 fortunately the engines not mine! I think it head gasket Quote Link to comment Share on other sites More sharing options...
