Arjan Posted May 6, 2021 Share Posted May 6, 2021 Obviously, asking for a friend 😊 As per title, if the said Discovery Td5 did not have the factory Cruise Control fitted, is it feasible to : 1 - retro fit the Cruise Control as per LR (and what is need - just an ECU and a switch ??) 2 - fit an aftermarket Cruise Control (suggestions / experiences please) Thanks. Quote Link to comment Share on other sites More sharing options...
teabag Posted May 6, 2021 Share Posted May 6, 2021 (edited) Just add the switch and of course system programming is required. http://www.discovery2.co.uk/cruise_install.html Edited May 6, 2021 by teabag Quote Link to comment Share on other sites More sharing options...
Arjan Posted May 6, 2021 Author Share Posted May 6, 2021 Ooohhh....... Very interesting. He doesn't seem to mention programming but I know a nice gentleman with a Hawkeye...... Thanks !! Quote Link to comment Share on other sites More sharing options...
Blanco Posted May 6, 2021 Share Posted May 6, 2021 15 minutes ago, Arjan said: He doesn't seem to mention programming Mine didn't need anything, it worked immediately.... and that was a French market vehicle, so don't expect any trouble. Quote Link to comment Share on other sites More sharing options...
Arjan Posted May 6, 2021 Author Share Posted May 6, 2021 Interesting..... Wonder what he'll say about that. Merci Beaucoup !! Â Quote Link to comment Share on other sites More sharing options...
bear Posted May 7, 2021 Share Posted May 7, 2021 No programing needed. Just plug and play. Did it to my 04 model Griff Quote Link to comment Share on other sites More sharing options...
Arjan Posted May 7, 2021 Author Share Posted May 7, 2021 Thank you. Quote Link to comment Share on other sites More sharing options...
Pawl12 Posted May 7, 2021 Share Posted May 7, 2021 Another 1 (TD5)Â here without programming. Just fitted the overide switch & the steering column switch and it just worked. Make sure when you buy the column switch you make sure it comes with the mounting bracket. The bracket can be fabricated, but it would be a unnecessary complication if you buy it ! Quote Link to comment Share on other sites More sharing options...
Arjan Posted May 7, 2021 Author Share Posted May 7, 2021 Thanks ! Quote Link to comment Share on other sites More sharing options...
