Clutch release bearings
reb78
Can anyone confirm if the clutch release bearings are the same on the LT77 for the Defender TDi and the R380 for the Discovery TD5? They look identical - I think they are p/n FTC5200 for both. I have a spare HD clutch release bearing from the old TDi box on the 110 and am wondering if it will fit the disco.
Worth checking as there are two different ones and they look identical but one is ~5mm longer or something silly - if you get them swapped you either have no clutch at all or clutch permanently held down, guess how we found this out...
