Bigj66 Posted May 9, 2021 Share Posted May 9, 2021 Anyone know why my compressor would suddenly decide to throw its oil out of the filler/breather? Gasket gone causing pressure in the sump is my guess but I’ve never worked on one before. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 9, 2021 Share Posted May 9, 2021 Could be head gasket, could also be rings, you could determine that with a compression test, are your breathers breathing ? Regards Stephen Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted May 9, 2021 Author Share Posted May 9, 2021 1 hour ago, Stellaghost said: Could be head gasket, could also be rings, you could determine that with a compression test, are your breathers breathing ? Regards Stephen I’ve no idea tbh, it just started spewing oil out of the filler neck so I assume it’s getting pressure from somewhere. I sense a strip down is in order. Quote Link to comment Share on other sites More sharing options...
