Jon1T Posted May 12, 2021 Share Posted May 12, 2021 (edited) I’m trying to work out the pipe between the clutch master and flexi hose on my v8 RRC. I was going to use copper brake pipe and standard fittings, but the 10mm male fitting into the master and female on to the end of the clutch flex don’t fit, so assuming they’re 12mm fittings? Also I can’t see a gasket fitting behind the clutch master to the bulkhead on the JLR classic parts site, but it looks like it needs one?? Any thoughts appreciated!! Jon Edited May 12, 2021 by Jon1T Quote Link to comment Share on other sites More sharing options...
