pilly44 Posted May 13, 2021 Share Posted May 13, 2021 can anyone help me i need to order a seal for my 1988 defender 110 rear halfshaft is this also called arear stub axle just need a part number and a diagram of where it is and is it a job i can do myself Quote Link to comment Share on other sites More sharing options...
western Posted May 13, 2021 Share Posted May 13, 2021 No seals on the half shaft/drive shaft. the stub axle is the part that stays on the main axle casing when the wheel/tyre & complete hub & brake assembly are removed, there is a seal in rear/inner face of the hub & a seal on inside of the stub axle. See page 427 [page number in top centre of page] rear drum brake/sub axle & driveshaft http://www.retroanaconda.com/landrover/parts_books/110/5_axles_suspension_steering_p398-471.pdf Quote Link to comment Share on other sites More sharing options...
pilly44 Posted May 15, 2021 Author Share Posted May 15, 2021 On 5/13/2021 at 10:27 PM, western said: No seals on the half shaft/drive shaft. the stub axle is the part that stays on the main axle casing when the wheel/tyre & complete hub & brake assembly are removed, there is a seal in rear/inner face of the hub & a seal on inside of the stub axle. See page 427 [page number in top centre of page] rear drum brake/sub axle & driveshaft http://www.retroanaconda.com/landrover/parts_books/110/5_axles_suspension_steering_p398-471.pdf thanks ill get one its just better to order with the part number thanks again Quote Link to comment Share on other sites More sharing options...
