Discovery 1 200tdi Windscreen seal
I've got a 94 200tdi Discovery that has a leaking screen. Does anyone have the part number for the windscreen seal? I seem to remember that later D1s have a different seal and i'm not sure if the ones i'm seeing online are the right ones. The photo is the seal thats currently in there.
Cheers
It's a two part seal.
The big bit is MWC8304 and Britpart do a reasonable version
Then there is the finisher strip which is DCB101510 but is better to buy from  a classic car specialist in a big strip, because I think you need four DCB101510
Why not remove the sealing strip, shown as no.3, clean and u may find the area of leak and reseal, then refit a new sealing strip if necessary.
Strip: LR part number MXC8199 strip facia to windscreen sealing. Is LRs description.
1994-5 it all changed to the 300 series with the MA 081991
 Share
