Tony Montana Posted May 19, 2021 Share Posted May 19, 2021 Hello all. 1994 Discovery manual 300tdi. My diff lock light is illuminated and no matter what I do with the stick the light won’t go out. It’s probably just me using it wrong. Any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
Blanco Posted May 19, 2021 Share Posted May 19, 2021 The diff lock can wind up the transmission unless you are off-road, so it might not pop out instantly when dis-engaged. If you have some gravel or slippery surface nearby then try driving in a circle or on nearly full lock for a few metres one way and then the other, should pop out then if there isn't any major problem. The diff-lock lever operates via a cable, it is usually reliable; I suppose it might have snapped when engaging the diff-lock in which case you will have to crawl under and physically disengage it with a screw driver or something. Ashcroft transmissions website have a video showing the fitting of the linkage to a D2, which would serve to give you an idea of the mechanism if needs be. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 19, 2021 Share Posted May 19, 2021 @Blanco I thought a 300TDi disco (D1) would be a lever/linkage not a cable? 1 Quote Link to comment Share on other sites More sharing options...
Blanco Posted May 20, 2021 Share Posted May 20, 2021 I spent a long time looking for a D1 lever assembly to convert mine* and ended up paying for the Ashcroft one which was a lever and cable assembly, I may be wrong but I thought it was more or less the same? either way the same logic applies, it is a basically reliable system, diff lock may just be wound up, or there is some problem with the mechanical connection between lever and gearbox?? *Land Rover things were much thinner on the ground in France at the time. Quote Link to comment Share on other sites More sharing options...
teabag Posted May 20, 2021 Share Posted May 20, 2021 This is what is stated in my D 1 owners handbook, it seem simples enough, as ive has never had to use diff lock in my 33 years of LR ownership. 1 Quote Link to comment Share on other sites More sharing options...
missingsid Posted May 20, 2021 Share Posted May 20, 2021 If the above does not fix it then I would be checking the warning light circuit to see if it is an electrical fault and lifting a wheel to see if the diff is in fact locked? Starting with the easiest option first. 1 1 Quote Link to comment Share on other sites More sharing options...
teabag Posted May 21, 2021 Share Posted May 21, 2021 I had a contractor at work that had a newish D1 200tdi so it was a few years a go, he had an issue with the light being permanent on, even after following the various procedures and advice giving, but soon after we heard he has crashed the disco on a roundabout which put him in hospital. We didn’t see him much after that, I still wonder if it was the locked diff locked or just his speed or both going around the roundabout as he did say he had trouble getting round but really didn’t know. Perhaps thats why LR state see your dealer as soon as poss if the diff lock light doesn’t extinguish. Quote Link to comment Share on other sites More sharing options...
steve b Posted May 21, 2021 Share Posted May 21, 2021 On 5/20/2021 at 9:03 AM, missingsid said: If the above does not fix it then I would be checking the warning light circuit to see if it is an electrical fault and lifting a wheel to see if the diff is in fact locked? Starting with the easiest option first. ^^This - Handbrake on , jack one front wheel up with gearbox in neutral and the wheel should be free to rotate . If it only goes a little way in either direction then the diff-lock is engaged . If it's free then remove the wire from the switch that goes into the loom and light should go out = switch fault , if the light stays on then a fault in the wiring cheers Steve 1 1 Quote Link to comment Share on other sites More sharing options...
missingsid Posted May 21, 2021 Share Posted May 21, 2021 Good explanation of my lazy suggestion. Quote Link to comment Share on other sites More sharing options...
Tony Montana Posted May 23, 2021 Author Share Posted May 23, 2021 Thank you everyone! Quote Link to comment Share on other sites More sharing options...
