remi Posted May 21, 2021 Share Posted May 21, 2021 (edited) Hello everybody. I'm driving a discovery 2 V8 ans I have a lot of problems. Now when I'm driving around 1500/2000 rpm,suddenly the engine rpm drop to 1000 and then come back to normal. Or I feel like a "push" or shocks when I'm driving Also it has less power and one time i heard a bang i think it was coming from the exhaust. I've put new spark plugs but I still have those problems. I don't know if I have to look at the ignition or the injector. Please if someone can help me Tks everybody Edited May 21, 2021 by remi Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 21, 2021 Share Posted May 21, 2021 If it's backfired it sounds like ignition or just a loose electrical connection knocking the whole system out momentarily - check your battery & earth connections. Quote Link to comment Share on other sites More sharing options...
remi Posted May 21, 2021 Author Share Posted May 21, 2021 (edited) The battery is new as well. It only backfired once. Otherwise Rpm goes down suddenly and i feel like push or shock like misfire and no power even with My foot all the way down hard to pass 1200 rpm sometimes Witch earth connection should I look at ? Edited May 21, 2021 by remi Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 23, 2021 Share Posted May 23, 2021 I'd check the main battery connections; battery to engine/starter and battery -ve to chassis & engine block. If yours has a distributor then the ignition amplifier module on the side loves to go faulty - usually they either fail as they get warm or fail once they cool down. Quote Link to comment Share on other sites More sharing options...
remi Posted May 23, 2021 Author Share Posted May 23, 2021 Thanks for the reply. I've 2 ignition modules behind the engine. Sadly I'm living in the middle of nowhere and I can't find someone to do a diagnostic on my engine. I was thinking about replacing those 2 ignition modules. Yestersay I've checked all the plug wires and they all look fine. I will check all ground cable today. I'll let you know if I can find the problem Quote Link to comment Share on other sites More sharing options...
teabag Posted May 24, 2021 Share Posted May 24, 2021 On 5/21/2021 at 6:56 AM, remi said: Hello everybody. I'm driving a discovery 2 V8 ans I have a lot of problems. Now when I'm driving around 1500/2000 rpm,suddenly the engine rpm drop to 1000 and then come back to normal. Or I feel like a "push" or shocks when I'm driving Also it has less power and one time i heard a bang i think it was coming from the exhaust. I've put new spark plugs but I still have those problems. I don't know if I have to look at the ignition or the injector. Please if someone can help me Tks everybody As the engine has full electronic management system and even linked to the auto gear box if fitted, the needs to be plug into a diagnostic test kit to give u an idea of what is what. Iffy o2 sensor are notorious for issues, the same as the other sensors for that matter. Quote Link to comment Share on other sites More sharing options...
remi Posted May 24, 2021 Author Share Posted May 24, 2021 Can o2 sensor or other sensor cause the engine to misfire ? Quote Link to comment Share on other sites More sharing options...
teabag Posted May 27, 2021 Share Posted May 27, 2021 They can easily contribute to an engine misfire, such as misinformation to the management system on the air fuel ratio as an example. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 27, 2021 Share Posted May 27, 2021 3 hours ago, teabag said: They can easily contribute to an engine misfire, such as misinformation to the management system on the air fuel ratio as an example. The reverse is also true - a misfire throws the O2 reading off because one or more cylinders is throwing unburnt fuel down the exhaust and can even coat the O2 sensor element, which throws it totally out of whack. Quote Link to comment Share on other sites More sharing options...
