ARB compressor fault
tobes
 Share
Mine took about 20 seconds odd and you could tell it was filling as the note of the compressor changed. If its actually filling (ie not leaking somewhere) then the pressure switch must not be working. I'm not really sure exactly where it is on the compressor as I've never stripped mine.
Guest diesel_jim
If you look at the top of the compressor, you'll see the one (or two) air solenoids, in between these is the pressure switch, it has 2 spade connectors on it going into the loom.
just been and had a look at it, one of the spade connectors is damaged but it is making contact. is the pressure switch available as a part to buy?
The compressor will run for more than double that time but i cant hear any leaks, it has air in it as it will pump out air when i connect the tyre hose.
 Share
