fearofweapons Posted May 23, 2021 Share Posted May 23, 2021 Hello! I'm looking for recommendations for windscreen sealent. Choices seem to range from 3M at nearly £17 per tube to ones at about £5. I've been told not to use tiger seal as it sets hard, windscreen sealent stays flexible. Many thanks Richard Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 23, 2021 Share Posted May 23, 2021 1 minute ago, fearofweapons said: Hello! I'm looking for recommendations for windscreen sealent. Choices seem to range from 3M at nearly £17 per tube to ones at about £5. I've been told not to use tiger seal as it sets hard, windscreen sealent stays flexible. Many thanks Richard Sikaflex its what the windscreen fitters use how many tubes do you need ? Regards Stephen Quote Link to comment Share on other sites More sharing options...
Blanco Posted May 23, 2021 Share Posted May 23, 2021 In a series you need a non -setting compound, ........ I think @Shackletonhas a great video on putting a non-bonded windscreen in . https://www.youtube.com/watch?v=_hhOIE3GEtE&t=725s The windscreen fitter gives all the details of what you need during the episode. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted May 23, 2021 Share Posted May 23, 2021 That link is a little late, go back to around 2mins 30 seconds to see the screen insertion from the beginning. The point about the Series screen is that it does NOT use a rubber seal, JUST the sealant. The advice given via the S2C forum is that it's wise to put 'something' solid in the base of the windscreen frame, to stop the screen sliding downwards over time. This is especially relevant to the modern heated screens, as they seem to be slightly smaller than the original panes. Go to 4.50 to see the Arbomast Windscreen sealant in use. Regards. Quote Link to comment Share on other sites More sharing options...
Northwards Posted May 23, 2021 Share Posted May 23, 2021 I would suggest Arbomast too. I had a windscreen professionally fitted (Defender rather than Series though) and it leaked. I thought I'd sorted it by dribbling in some Tolley's crack cure - but after a little off road trip it was back. I'm now assuming the Tolleys stuff is Ok until the joint flexes, then the seal is broken. I went back to the windscreen fitter and they put in some Arbomast on the basis of its staying flexible. I've since got some more myself to re-do the alpine lights, as I think the Tolleys stuff has gone the same way there. Quote Link to comment Share on other sites More sharing options...
fearofweapons Posted May 23, 2021 Author Share Posted May 23, 2021 Thanks for the suggestions guys, Re Sikaflex - any particular one? There are so many numbers! e.g. Adhesive Sealants - Sikaflex?-255 FC Primerless Windscreen Glazing Adhesive 300ml Black | Sealants Online For Arbomast - I found this? ARBO Arbomast Autograde Black 380ml - Sealants & Tools (sealantsandtools.co.uk) Is this correct? thanks, Richard Quote Link to comment Share on other sites More sharing options...
steve b Posted May 23, 2021 Share Posted May 23, 2021 Eastwood flexible caulk strip from www.frost.co.uk works well for screen glass , fixed door top glass , floor panels and seatbox Steve Quote Link to comment Share on other sites More sharing options...
Peaklander Posted May 23, 2021 Share Posted May 23, 2021 1 hour ago, fearofweapons said: For Arbomast - I found this? ARBO Arbomast Autograde Black 380ml - Sealants & Tools (sealantsandtools.co.uk) Is this correct? Yes that’s what I have seen used and I’m just about to buy a tube for my new back door glass (Defender). I’m getting it from an eBay seller at £10.95 delivered which is almost the same delivered cost as your link. Quote Link to comment Share on other sites More sharing options...
fearofweapons Posted May 23, 2021 Author Share Posted May 23, 2021 Thanks everyone for your input. I have ordered some Arbomast. If that does not work I'll get some of the DumDum substitute. regards, Richard Quote Link to comment Share on other sites More sharing options...
