Loowee Posted May 25, 2021 Share Posted May 25, 2021 Hey guys. I just received and changed the 2 rear shock dampers on my Disco Sport 2017. I noticed the new damper did not have the electronic connectors but I figured I never used the option so no need for it. All in all, everything is back as smooth as day one but I do get the annoying "Adaptive dynamics fault" in my dashboard. I own a HSE so I guess what I installed is the non-HSE version. Any quick tip to disable the warning in the dashboard ? I wonder if the wire shorting trick like the brake sensors work but I doubt it since these wires most likely have control voltage for a small pump versus a simple contact sensor. A resistor on the wires would probably do the job but can anyone provide me on the electrical specs for this wire strip ? Thanks in advance ! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 30, 2021 Share Posted May 30, 2021 I don't think there are many D Sport owners on here to be honest. Sorry - I don't know anything about them! Quote Link to comment Share on other sites More sharing options...
Loowee Posted June 17, 2021 Author Share Posted June 17, 2021 Thank you BogMonster. It's probably a general adaptive suspension connection. Someone somewhere must know what resistance this little pump needs to stop the onboard system from detecting a problem. :/ Quote Link to comment Share on other sites More sharing options...
elbekko Posted June 18, 2021 Share Posted June 18, 2021 You can try buying a day's access to Land Rover's online workshop manuals. Maybe some more information is in there. Quote Link to comment Share on other sites More sharing options...
Escape Posted June 18, 2021 Share Posted June 18, 2021 You could start by measuring the resitance of the old dampers if you still have them. Quote Link to comment Share on other sites More sharing options...
