Longshanks68 Posted June 4, 2021 Share Posted June 4, 2021 Hi , as per previous post still have some wiring issues on my 1992 classic project. Doesnt crank from the ignition, so have followed the red and white wire to the relay where it sends power to a small black /yellow wire . This should feed a orange/brown wire which goes to the inhibitor switch on the gearbox. I have traced the wire and they go to a round plug (pictured ) but it's not connected to anything, and I cant see where it should be connected to. If I bridge the yellow/black to the orange/brown. It sends power to the inhibitor and cranks from the key. So my question is does anyone know where it should connect to. It's on the drivers side inner wing just in front of the ABS unit. Seems like I have some wiring missing. There are around 10 wires in the plug so I am guessing they should all connect to something. It's a 1992 3.9 V8 If any one has any ideas it would be greatly appreciated. Thanks Neil Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 5, 2021 Share Posted June 5, 2021 Do you have the wiring diagrams for the car? They're in the RAVE manuals (downloadable for free if you google) and for that era might even have the location photos for every connector. Quote Link to comment Share on other sites More sharing options...
Longshanks68 Posted June 5, 2021 Author Share Posted June 5, 2021 Hi , Thanks for the reply No only got a Haynes manual but the one I have only goes up to 1990. Tried searching online but had no luck Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 6, 2021 Share Posted June 6, 2021 I don't know if stuff changed from 1990 to 1992 but I thought most of the systems stayed the same after the swap to Hotwire EFi & ABS until the P38 came along. I'm not finding any manuals in my collection that are specifically 1992. Have a look here, there's a few that may be of use: https://fuddymuckers.co.uk/rtfm/RangeRover/RRC/ Quote Link to comment Share on other sites More sharing options...
Longshanks68 Posted June 6, 2021 Author Share Posted June 6, 2021 Thank you very much for the info . Much appreciated Quote Link to comment Share on other sites More sharing options...
LiftedDisco Posted June 6, 2021 Share Posted June 6, 2021 92 will be a bit of a challenge as they seemed to make it up as they went... it’s something of a transition year and there’s very little (seemingly) available as wiring diagrams etc I’ve got the remains of a loom from a 92 - will have a go through it tomorrow to see if I can identify the plug that you have shown... Quote Link to comment Share on other sites More sharing options...
Longshanks68 Posted June 10, 2021 Author Share Posted June 10, 2021 Thank you drawn a blank so far trying to find another owner of a 92 classic local to me. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 11, 2021 Share Posted June 11, 2021 Have you checked it's not just some optional equipment plug that you don't have fitted - did those years come with air suspension for example? Trying to think of things that would warrant a 10-way plug randomly floating in the engine bay Also have you traced back from the starter to confirm that you don't have continuity to the start switch - this plug could be a red herring. Quote Link to comment Share on other sites More sharing options...
Longshanks68 Posted June 12, 2021 Author Share Posted June 12, 2021 Hi , thanks for the reply. I have traced the red /white wire from the ignition switch to a relay then out of the relay it becomes black/yellow. This wire runs to the round plug pictured. The starter wire is dead until I bridge it with a piece of wire to the brown /orange wire. This is the same colour wire as the one that goes to the inhibitor switch. Once its bridged the starter wire becomes live when the key is turned to the cranking position. I was hoping someone had a 1992 model and could loom at their wiring to see if they have this plug too. Thanks Neil Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 14, 2021 Share Posted June 14, 2021 The Range Rover Register may have some technical docs or expertise that us mere mortals don't, could be worth firing them an e-mail. Quote Link to comment Share on other sites More sharing options...
Longshanks68 Posted June 14, 2021 Author Share Posted June 14, 2021 Hi , thanks for the reply will give them a try Quote Link to comment Share on other sites More sharing options...
Longshanks68 Posted August 10, 2022 Author Share Posted August 10, 2022 Just thought I would update the post incase anyone else comes across this problem. Turns out the connector in question was connected to the central locking and alarm system . It seems the previous owner has removed a section of the harness. Another job to add to my list . Quote Link to comment Share on other sites More sharing options...
