Gazzar Posted July 18, 2021 Share Posted July 18, 2021 I was disassembling done doors, taking off the tops, and the stud that ties the two together came out of the aluminium housing instead of the nut coming off. Take a good look at the stud..... 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 18, 2021 Author Share Posted July 18, 2021 Guess which end was in the inaccessible aluminium casing? Quote Link to comment Share on other sites More sharing options...
Eightpot Posted July 18, 2021 Share Posted July 18, 2021 Clearly you have been spared but only to suffer a worse fate. Never try to beat the system, you should have made efforts to snap the bolt as prescribed 🙁 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 18, 2021 Author Share Posted July 18, 2021 Ah, the other one has a snapped bolt in it already. I think that should suffice, I hope. What's the acid that eats steel but not aluminium? Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted July 19, 2021 Share Posted July 19, 2021 8 hours ago, Gazzar said: Ah, the other one has a snapped bolt in it already. I think that should suffice, I hope. What's the acid that eats steel but not aluminium? It's called Galvanic Corrosion and is the result of dissimilar metals and water. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 19, 2021 Author Share Posted July 19, 2021 Yes, I know a little bit about Galvani and the cells, but there an actual acid that might eat the steel out of the aluminium for me. Rather than me drilling/welding/tapping the remainder of that stud out. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 19, 2021 Author Share Posted July 19, 2021 Alum! Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted July 23, 2021 Share Posted July 23, 2021 On 7/19/2021 at 9:27 AM, Gazzar said: Yes, I know a little bit about Galvani and the cells, but there an actual acid that might eat the steel out of the aluminium for me. Rather than me drilling/welding/tapping the remainder of that stud out. Apologies, I misunderstood the question. You'll probably have to go mandraulic on the removal of the bits, with copious use of a good penetrant oil to assist. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted July 23, 2021 Author Share Posted July 23, 2021 Thanks, it's a job for another year. Quote Link to comment Share on other sites More sharing options...
