Hawklord Posted July 27, 2021 Share Posted July 27, 2021 Can anyone confirm what I need to remove on my 300TDI to replace the reversing light switch as some sites say that it can be accessed by removing the panel under where the center seat would be (I have a cubby box) and others say that the gearbox tunnel has to be taken out. Quote Link to comment Share on other sites More sharing options...
western Posted July 27, 2021 Share Posted July 27, 2021 300Tdi/R380 reverse switch lives on left side of the gearbox, If your vehicle is factory built then to access the location the gearbox tunnel cover has to be removed, R380 close up C0167 forward of the tunnel rear flange. LLT77 gearbox reverse switch on rear face Quote Link to comment Share on other sites More sharing options...
simonpelly Posted July 27, 2021 Share Posted July 27, 2021 Do you have a problem with the switch? I may have an old working one if you need one that you can have. Let me know and I'll root around the garage. Simon... Quote Link to comment Share on other sites More sharing options...
Hawklord Posted July 28, 2021 Author Share Posted July 28, 2021 Many thanks for the offer but I already have a new switch. It was picked up at the last MOT (although it is not a failure item) so I will try and sort it out before the next one. Quote Link to comment Share on other sites More sharing options...
