Door card fixings
If they're like the door cards fixings on the rear doors from the same era, they are screwed into plastic inserts in the frame. I can get a photo this evening if that helps.
On mine, they're the plastic pin-rivet things that also hold on the wheel arches, two each card (top left/bottom right)
Rivet: MWC9918PMA
Insert to door: MWC3136
Some diagrams say it's these, but I have found they don't grip as well: MWC9917
I've just fitted my doors out so this is what worked for me.
  • Like 1
  • Thanks 1
Rivet: MWC9918PMA
That’s exactly what should be there, though they’re a similar grey rather than the black of the wheel arch type.  Halfords and other motor factors sell similar sized rivets with screw out centres, so you can reuse the same rivets repeatedly.  Only trouble is finding them in grey.
