Bigj66 Posted August 5, 2021 Share Posted August 5, 2021 Does anyone know if it possible to buy the aluminium window spacers without also having to buy the channels? Quote Link to comment Share on other sites More sharing options...
simonb Posted August 5, 2021 Share Posted August 5, 2021 (edited) MTC3180 lower, 330202 upper, 330203, vertical (long one) available various places if you Google them. Use sealant between them them door frame and the felt channels to prevent as much water as possible getting into the door top bottom frame.. Yours are good enough to reuse if you flatten out the pulled holes. Doesn't matter if you drill new holes through them - the window channel will hide that. Edited August 5, 2021 by simonb Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted August 5, 2021 Author Share Posted August 5, 2021 10 minutes ago, simonb said: MTC3180 lower, 330202 upper, 330203, vertical (long one) available various places if you Google them. Use sealant between them them door frame and the felt channels to prevent as much water as possible getting into the door top bottom frame.. Yours are good enough to reuse if you flatten out the pulled holes. Doesn't matter if you drill new holes through them - the window channel will hide that. Cheers I’ve just found them using the part number. For £40 for a set though, I’ll stick with these I have here.👍 Quote Link to comment Share on other sites More sharing options...
