danicklin Posted August 8, 2021 Share Posted August 8, 2021 Now that I've finally found the correct replacement belts and got the engine running smoothly, I have been driving the fleet of Land Rovers around the property and diagnosing other issues. When driving over some un-even terrain, I noticed that one of the vehicles would easily rock side to side and make a clunking noise. After inspection it seems that bottom nut of the shock absorber is hitting the bottom of the spring mounting plate. There seems to be a considerable gap either side. Can this be easily adjusted or does it mean the shocks need to be replaced? Quote Link to comment Share on other sites More sharing options...
Giles Posted August 8, 2021 Share Posted August 8, 2021 Hi, You need some bushes There should be two in total at the bottom of each damper: one on either side of the spring plate thing. The part no. is 552818 .... good luck ! Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2021 Share Posted August 8, 2021 You need items 3,4,5,6 on here http://new.lrcat.com/#!/1228/7048/7554/674 Click the item number & the part number will or should appear below the diagram. Quote Link to comment Share on other sites More sharing options...
Lightning Posted August 8, 2021 Share Posted August 8, 2021 Looking at the state of that lower shock bolt, it would probably be worth fitting two new shocks, they are only cheap and will come with all the correct bushes and new nuts as well. 1 Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 8, 2021 Share Posted August 8, 2021 What he said^^^ Some Monroe shocks will do you fine - think they or Armstrong are the OEM. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 8, 2021 Share Posted August 8, 2021 Looks to me like the shock body has parted company with the stud and nut ! Mo Quote Link to comment Share on other sites More sharing options...
Wytze Posted August 10, 2021 Share Posted August 10, 2021 Do the bottem three coils of the spring normally sit on one and other? If not , you need two springs aswell. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted August 10, 2021 Share Posted August 10, 2021 1 hour ago, Wytze said: Do the bottem three coils of the spring normally sit on one and other? If not , you need two springs aswell. Yes, 110 springs are closed at the bottom and open up when the axle articulates 1 Quote Link to comment Share on other sites More sharing options...
