Arjan Posted August 9, 2021 Share Posted August 9, 2021 I learned something this weekend from a true engineer ! A grease gun can actually push out even real stubborn pistons.... Merci Beaucoup Taurion !!!! 2 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 9, 2021 Share Posted August 9, 2021 Hardly surprising when you consider they are used to tension several tonnes of excavator track 1 Quote Link to comment Share on other sites More sharing options...
L19MUD Posted August 9, 2021 Share Posted August 9, 2021 3 hours ago, Arjan said: I learned something this weekend from a true engineer ! A grease gun can actually push out even real stubborn pistons.... Merci Beaucoup Taurion !!!! This reminds me to push the pistons out on the 110 before I start disconnecting brake pipes. Was a nightmare on the 90 - I had to resort to welding bolts to them!! Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 9, 2021 Share Posted August 9, 2021 Nice tip, I'm starting to get a collection of these tips brake piston removal tips. Depending on the size of the piston you can place a socket in it and then place a 1/2 drive next to the socket and it will jam up allowing you to twist the piston out ..... also for motorbike size brake piston you can get a slide hammer kit for a few pennies. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 9, 2021 Share Posted August 9, 2021 Tried that before on a set of calipers, I am sure it will work for some, but not in my case... In the end I stuck an old bolt in the centre of it and turned the welder up to eleventy and welded it to the piston. After grabbing it with a pair of mole grips, the piston soon gave up the fight, and I topped up my tan a little at the same time 😛 1 Quote Link to comment Share on other sites More sharing options...
Arjan Posted August 9, 2021 Author Share Posted August 9, 2021 Another friend has modified an old hydraulic jack for this. So far, everything came out.. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted August 9, 2021 Share Posted August 9, 2021 13 minutes ago, Bowie69 said: Tried that before on a set of calipers, I am sure it will work for some, but not in my case... In the end I stuck an old bolt in the centre of it and turned the welder up to eleventy and welded it to the piston. After grabbing it with a pair of mole grips, the piston soon gave up the fight, and I topped up my tan a little at the same time 😛 my exact experience to date!! Quote Link to comment Share on other sites More sharing options...
taurion Posted August 9, 2021 Share Posted August 9, 2021 We wanted to reuse the pistons, which are stainless steel, so I had to find a non-destructive method of getting them out. 1 Quote Link to comment Share on other sites More sharing options...
Badger110 Posted August 10, 2021 Share Posted August 10, 2021 20 hours ago, Ed Poore said: Hardly surprising when you consider they are used to tension several tonnes of excavator track Blew me away when I first learnt to do this on a 22T machine...to this day I still believe an alternative universal force is at play 2 Quote Link to comment Share on other sites More sharing options...
De Ranged Posted August 12, 2021 Share Posted August 12, 2021 On 8/9/2021 at 8:21 PM, Arjan said: I learned something this weekend from a true engineer ! A grease gun can actually push out even real stubborn pistons.... Merci Beaucoup Taurion !!!! Use a lever style grease gun they have a higher pressure... I think the good ones get to 1500psi Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 12, 2021 Share Posted August 12, 2021 14 hours ago, De Ranged said: Use a lever style grease gun they have a higher pressure... I think the good ones get to 1500psi Get yourself a Wanner and have at it! 1 Quote Link to comment Share on other sites More sharing options...
De Ranged Posted August 12, 2021 Share Posted August 12, 2021 16 minutes ago, FridgeFreezer said: Get yourself a Wanner and have at it! Never heard of them... did a google search, 8 and half thousand PSI on a pistol grip grease gun lol I stand corrected that is a beast of a grease gun! Now to find some one who will ship one to New Zealand lol Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 12, 2021 Share Posted August 12, 2021 1 hour ago, De Ranged said: Never heard of them... did a google search, 8 and half thousand PSI on a pistol grip grease gun lol I stand corrected that is a beast of a grease gun! Now to find some one who will ship one to New Zealand lol We picked up a couple from the local scrapyard for pennies because the name was amusing, but they've since become something of a workshop favourite for obvious reasons. Quote Link to comment Share on other sites More sharing options...
missingsid Posted August 13, 2021 Share Posted August 13, 2021 I used to have one but can't find it now, argh! Never realised it was that high preasure. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted August 13, 2021 Share Posted August 13, 2021 Nothing like a good Wanner! 1 Quote Link to comment Share on other sites More sharing options...
mmgemini Posted August 15, 2021 Share Posted August 15, 2021 On 8/13/2021 at 10:46 PM, Happyoldgit said: Nothing like a good Wanner! You must have had a Mini at some point lol Quote Link to comment Share on other sites More sharing options...
Romahomepete Posted August 16, 2021 Share Posted August 16, 2021 My Wanner grease gun is more than 50 years old and has had a hard life. It still works like new it is the mutts nuts and the standard that every other grease gun should be judged by. Peter Quote Link to comment Share on other sites More sharing options...
